1 X 4 Or 1 X 6 Pine Beadboard Or V Groove - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2009, 04:03 AM   #1
1 x 4 or 1 x 6 Pine beadboard or V groove
I've just gutted my 500 ft2 home and want to put either 1 x 4 pine beadboard or the 1 x 6 pine v groove on the walls and ceilings. No drywall here.
I figure I'll need about 2000 ft2 of board. Is there anywhere I can purchase this much without going to Home Depot or Lowes? I'd love to find a sawmill and purchase what I need. Any ideas or leads will be greatly appreciated.
I'm in Saint Petersburg, Florida Thanks, Joe
doctorjoeypemhs is offline   Reply With Quote
Old 10-25-2009, 07:52 AM   #2
Too Short? Cut it Again!
I should think your local building supply or lumber yard would be happy to order the material, in whatever wood, grade and configuration you wanted. They will probably even deliver it! You could check online too. Nobody checks the crap at the box stores so plan on standing there for a day or so just to sort what you need. You cannot even trust those with a halfway decent contractor department when it comes to this sort of thing. And of course, they will not have as much as you need on hand and will not be able to tell you when, or if, they can get more to match.
Old 10-25-2009, 08:15 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
they also make it in 3/8"x 3-1/2" X 16' primed finger joint. I used this product allot on Reno work. What I do is install 1/2 Plywood over the studs so I have nailing in all areas.This type of product can be bought at a real lumber yard not Lowe's or Home Depot. Check this site out.www.beadboard.com/uploads/downloads/BeadBoard-Catalog.pdf
Old 10-25-2009, 08:21 AM   #4
And don't just think wood. If you are going to paint it, there are all kinds of nice recycled materials configured into the look you seem to want to achieve. Surfaced bamboo ceilings and walls are becoming more popular too but I have not yet seen it configured as beadboard.
Old 10-25-2009, 11:04 AM   #5
General Contractor
Look for a millwork supply company in the phone book or by searching on Google. The amount you need is going to be well over the minimum orders generally required. You could also save quite a bit of money since you will be eliminating the retail mark up. A quick Google search brought this up for me:
www.manta.com/mb_44_E01AF_10/millwork/florida
ARI001 is offline   Reply With Quote
Old 10-25-2009, 11:17 AM   #6
DIY staff
Rewards Points: 7,174
This guy has a nation wide list of small sawmills.some may do milling also.I buy most of my cherry and oak from small mills--at great savings,Good luck.-MIKE-Nelsonwoodworks.biz - Home
Here is another lead:The Forestry Forum - Index
Old 10-26-2009, 09:13 PM   #7
Remodeling Contractor
Go to midwestlumberinc.com and check out their Pyramid Peak prefinished v-groove pine. I install quite a bit of this product and absolutely love it. If you call them, they will help you find a dealer near you. The ends are tongue and groove also, so you don't have to land on a stud or ceiling joist, making install fast and easy, with virtually no waste. Also it has a high quality finish already applied.
eisert is offline   Reply With Quote
Basswood vs Pine Paneling duck2 Carpentry 7 06-08-2015 11:30 AM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 02:01 PM
The pine tongue and groove has no brenda o General DIY Discussions 38 10-31-2009 01:13 PM
Beadboard on balcony Cecosugi Building & Construction 3 09-16-2009 03:00 PM
Granite backsplash over beadboard? Asil65 Building & Construction 10 03-23-2009 12:02 PM
