Old 01-18-2011, 03:10 AM   #1
1 inch gap between sheetrocks and subfloor
The wall of my house is about 1 inch taller than 8 feet. So there is a 1 inch gap between sheetrocks and the subfloor. I know I will cover it up with baseboard. However I am curious if my sheetrock contractor screwed me up by leaving that gap there? I am going to lay tiles by myself soon. Should I do something about it before I start?
Thanks for any heads up.
pttcc is offline   Reply With Quote
Old 01-18-2011, 04:33 AM   #2
If the sheet rock is not part of your air barrier system, then cover it and forget it, once you check it structurally, IMO. If you only have a single bottom plate on the wall (never heard of a double one), then you are not catching that plate by much. I'd ensure that the 'rock is well attached to the bottom plate. Maybe add a few longer screws are in order?
The Following User Says Thank You to jklingel For This Useful Post:
pttcc (01-18-2011)
Old 01-18-2011, 08:16 AM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
It this is in a bathroom, 1" off the floor is about right to keep the Gypsum from getting soaked if the tub overflows.
The Following User Says Thank You to gregzoll For This Useful Post:
pttcc (01-18-2011)
Old 01-18-2011, 08:21 AM   #4
Sheetrock is generally hung with 1/2" to 1" gap: Tight against the ceiling.
Just make sure that your baseboard nails aren't in that first inch, otherwise the boards won't sit flat.
I personally wouldn't attach it to the bottom plate. Ataching at the 16" O/C studs should be sufficient.
michaelcherr is offline   Reply With Quote
The Following User Says Thank You to michaelcherr For This Useful Post:
pttcc (01-18-2011)
Old 01-18-2011, 02:53 PM   #5
Not attaching to the bottom plate is probably a better idea. I tend to overkill the tightness on most everything, and I think this is one place where leaving it "loose" is better, like floating it at edges in the lid, esp over interior load bearing walls. Good idea.
pttcc (01-18-2011)
