1/4 Vs 1/2" Hardiebacker - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 08:45 PM   #1
Rewards Points: 1,062
Question
1/4 vs 1/2" hardiebacker
i am curious if it is alright to use 1/4" hardiebacker on top of 3/4" subfloor if tile goes on top.
if so is the case, i am curious why anyone would ever need 1/2" because you will use 3/4" subfloor anyway (or is this assumption wrong?).
thanks
Old 04-11-2011, 10:35 PM   #2
Rewards Points: 5,336
The 1/2" material is used in a wall application without the support the flooring gives the material.
The substrate needs to be adequate for tile. Applying hardiebacker to an inadequate subfloor doesn't make it suitable for tile.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
amakarevic (04-11-2011)
Old 04-11-2011, 10:48 PM   #3
Question
yeah but 3/4" OSB subfloor should be adequate, no?
Old 04-11-2011, 10:58 PM   #4
I wouldn't tile over just 3/4" OSB. If the joists were the correct size and the span was within parameters, I would add another 5/8" ply over the OSB. Glued and screwed.
What are the size of the joists, their spacing, and the distance they span?
Ron
Old 04-11-2011, 11:51 PM   #5
it's an old house so the joists are 2x10 but the original size (meaning really 2"). this is for a boiler/water heater alcove. the joists are about 14-15" apart.
Old 04-12-2011, 07:28 AM   #6
Old house means 1x6 or so subfloor? How do you have OSB?
What is your definition of an old house?
In either case, I wouldn't put tile on a single layer of OSB with hardibacker.
Check out the John Bridges Forum for substrate recommendations.
Ron
Old 04-12-2011, 03:53 PM   #7
it is 102 yrs old and yes, the previous subfloor that i ripped out were 1x3 pine. i had to rip i out to make it cleaner for plumbing works.
trust me, there is no sagging
Old 04-12-2011, 04:07 PM   #8
SteelToes's Avatar
Rewards Points: 150
It all depends on the type of the tile you are putting down.
You need to calculate subfloor deflection limit.
http://www.apawood.org/pablog/index....Desk-Question-
Deflection-of-Subfloor-Sheathing-for-Ceramic-Tile-Floor-Assemblies
http://www.awc.org/calculators/span/...rcalcstyle.asp
http://www.johnbridge.com/vbulletin/deflecto.pl
SteelToes is offline   Reply With Quote
5/8" sheetrock and 1/2" hardiebacker problem pttcc Tiling, ceramics, marble 9 02-03-2011 02:51 PM
So blasted confused about hardiebacker and vapor barriers ajtool Kitchen & Bath Remodeling 7 12-16-2010 08:43 PM
Hardiebacker/ Floor Tiling question.......remaking the "BOMB SHELTER!" Dyoung Building & Construction 5 03-20-2010 09:09 AM
Hardiebacker.... vapor barrier TAR ? Dyoung Building & Construction 1 02-26-2010 07:37 PM
Hardiebacker over tile? el_goodo Flooring 9 02-16-2009 08:06 AM
