1/4" Plywood Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 08:30 PM   #1
1/4" plywood floor
Hi, I am having an addition put on my house & they have the foundation & crawl space in & then put in 1'4" plywood for the floor, nothing else. This is going to be a small house addition & the floor is already warped before the roof & sides were up. It is getting more unstable & they are putting the walls up now. Am I wrong in thinking the flooring is not correct since it isn't stable. I have repeatedly talked to them about fixing it & they said it will be fixed after the walls are up... WHAT? Do I want walls setting on 1'4" plywood? I'm not happy about this but if it is the right way to do it I'll give them a break. Thank you & I hope I'm in the right forum.
llorain63 is offline   Reply With Quote
Old 10-09-2010, 10:10 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Do you have a permit? - That would protect you from the construction you getting, which is totally improper, out of line and approaching insanity. It would never be approved when a permit is applied for and not if it ever got to inspection - This is assuming that your description of what you have is 1/4" plywood and nothing else spanning between floor joists.
Dick
Dick
concretemasonry is online now   Reply With Quote
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
how to fasten plywood to subfloor to even out floor height cmlcsu Flooring 11 11-08-2009 10:19 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
