1-2x6 Stud Cut Through On Load Bearing Wall. 2 Top Plates Still In Tact. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 10:28 PM   #1
1-2x6 Stud Cut Through on load bearing wall. 2 top plates still in tact.
I hired a contractor to build some office space in a warehouse space with a second floor mezzanine. Long story short I've noticed there was 1-2x6 stud cut at the top of the 2x6 on a 14 foot wide load bearing wall (Looks like the Fire Sprinkler Installer Cut through the stud to hang his 3" pipe from the floor joists above and that 2x6 seemed to be in the way).
The two sandwiched 2x6's making the top plate supporting the i-Joists at the top of the wall have not been touched. The stud and floor i-Joist system was framed @ 19.2 On Center. So now in one section of that wall the closest 2x6 studs are 38.4" apart, with the Sandwiched 2x6's top plate spanning the 38.4".
Is this a cause for concern?
raguy55 is offline   Reply With Quote
Old 03-22-2012, 10:45 PM   #2
Rewards Points: 13,752
A picture sure would have been nice.
Tags
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Wine rack as load bearing wall? lisa7932 Building & Construction 5 02-27-2012 12:53 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
