Old 05-07-2007, 09:56 AM   #1
They're all fixer-uppers
J187's Avatar
Default 1 1/2" Insulation??
While remodelling my finished basement, I pulled the 1/4" wood panelling preparing to drywall. Upon doing so, I found that the exterior wall in question was insulated with an old Owens Corning kraft faced insulation. My first thought was "wow, rodents have eaten most of this." But then I started to realize that it was uniformly paper thin across the whole wall. I looked for some markings and found the kraft paper stamped with "1 1/2" insulation". I've never heard of such a thing - 1 1/2" insulated exterior wall Plus 1/4" wood panelling, no wonder we always have to use a space heater in that room.
TRY IT, IT'S SO MUCH FUN!
J187 is offline   Reply With Quote
More On This Topic
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. As an inspector and I inspect a lot of these homes and check them to make sure that our... Read More »
Garage Wall Insulation Tips
Garage Wall Insulation Tips by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about insulation tips. Now that our wall is fully framed in, we can go ahead and insulate. When buying insulation, there is a couple of things that you want to look for... Read More »
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. So we've got R-Value of roughly one R-Value per square inch of wood. So in other words, that... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Rigid insulation question Endeavor General Discussion 2 07-17-2007 12:27 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 06:04 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 10:33 PM
Insulation material reusable? KUIPORNG General Discussion 4 06-19-2006 04:38 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
