Zip Tying At A Staple - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2013, 11:21 PM   #1
zip tying at a staple
With regards to fastening a wire within 8" of a non-clamped box:
Is it compliant to zip tie to a wire that is already stapled? Just a single tie, at the staple, and not bundling or anything like that. Wasn't sure if a staple is required, or if that's fine.
While I'm at it, for a wire that runs across an attic and into a ceiling light to a room below, is that wire required to be stapled within 8" as well, or is it different for an accessible area, such as an unfinished attic?
Thanks.
Tonglebeak is offline   Reply With Quote
Old 08-26-2013, 08:45 AM   #2
Rewards Points: 150
Not sure about zip ties but anywhere you have access to the wiring, such as unfinished attic, wires must be stapled. When I built and wired my house, there was a wire I forgot to staple to the ceiling joists in the unfinished attic and the inspector raised hell about that. But he passed me after I fixed that.
romex1220 is offline   Reply With Quote
Old 08-26-2013, 09:52 AM   #3
Just stapled 8" within the box, correct? Or does it have to be stapled every 4 and a half feet, even though the ceiling joists are supporting the wire.
Old 08-26-2013, 10:03 AM   #4
Rewards Points: 150
That will depend on your local codes. But most of them want around 6-12" from box to take the stress off of the wires in the box and around every 4 feet stapled. It needs stapled because its accessible to being pulled on or tugged but check with your local codes because they might not require this but most do
Old 08-26-2013, 10:51 AM   #5
I just did more research. It appears that my attic entry would be considered a scuttle hole since there's no permanent stairs or ladder, so they just simply require guard strips within 6'.
What exactly is a guard strip? I've got so much insulation up there and it's going to be a huge PITA.
Old 08-26-2013, 11:04 AM   #6
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Guards strips aka running boards.
wirenut1110 is offline   Reply With Quote
Old 08-26-2013, 11:10 AM   #7
I've never heard of such a thing. Are these boards that just run parallel to the joists or something? If so, what do they do? Are the wires supposed to be stapled to those or something? If so, which side of the board? Talk to me like I'm a 4-year old when it comes to that please
Old 08-26-2013, 11:38 AM   #8
Rewards Points: 510
If you're running wire parallel to the joists, you can just staple the wire to the joist.
Running boards are when you run wire perpendicular to the joists (wire lays on top) and the running board goes beside it to keep it from being stepped on or something being placed on top of.
I just try to keep the wiring out of the area where you can walk or store stuff. Close to the eave where the roof/wall meet.
The Following User Says Thank You to wirenut1110 For This Useful Post:
Philly Master (08-27-2013)
Old 08-26-2013, 02:14 PM   #9
So in my case, I kind of fished the wire from the center of a bedroom, to an interior wall, trying to avoid all of that insulation. It runs diagonally to the floor ceiling joists. So I just simply nail a 2x4 next to the wire? Does the wire then need to be nailed to the side of the board, or can it be nailed on the top of it?
Thanks.
Old 08-26-2013, 02:48 PM   #10
Rewards Points: 510
This is really left to interpretation.
What I quoted works for me but, it seems, some people want it on both sides of the wire, like a channel.
Also, you only need to do the portion that's within 6' of the scuttle hole.
You wouldn't want to staple the wire on top, that would just be defeating purpose. No different than it being on top of the joists.
Old 08-26-2013, 03:17 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
I've never heard of a local amendment to the NEC with different securing requirements, but I guess it's possible.
Code is 12" from a box, or 8" from a single-gang non-metallic box with no clamps or grips for the cable. Then every 4-1/2' thereafter.
Through bored holes is considered supported. Laying on top of framing is not.
Old 08-27-2013, 06:17 AM   #12
Philly Master's Avatar
Rewards Points: 516
8" if the box does not have a clamp ..ie single outlet blue box ... or 12" if it has a clamp inside the box for your first staple/or attachment
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-27-2013, 07:58 AM   #13
Rewards Points: 3,130
Wow, Atilla the Inspector. I passed my final electrical with a couple of receptacle cover plates missing. He just didn't notice.
Old 08-27-2013, 05:26 PM   #14
As to the original question, this is what I was talking about:
http://img819.imageshack.us/img819/1610/w7u7.jpg
Old 08-27-2013, 06:16 PM   #15
Sparky
Rewards Points: 510
No, you're using a cable to support a cable. 300.11(c)
If the cable tie went around the staple it would be acceptable
Techy is offline   Reply With Quote
Staple up, warmboard or gypsum concrete? jelly HVAC 6 08-17-2011 12:35 AM
Staple Gun Bob Guercio Tools 5 04-19-2011 10:55 PM
What staple gun or nail gun for subfloor justdon Flooring 4 03-31-2011 04:16 PM
Through the joist into the canister, staple? epeterson777 Electrical 12 02-08-2009 10:06 PM
wire staple removal madmax55555 Electrical 8 07-03-2006 06:29 PM
