Zenith Motion Sensor Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-24-2012, 09:20 PM   #1
Hi guys,
I'm new here and have some questions about wiring up a Zenith DualBrite Sensor Head (Model 5716) to our house lighting. Originally, we had a contractor install the sensor and lights, but recently the sensor died and we're trying to figure out how to rewire a new one up to the house.
The basic setup of our wiring is that the power is passed to a light switch, and from there the 2 lamps and motion sensor are connected to that. I took a picture and labeled the relevant parts of the wiring:
Now, I'm trying to follow the manual to hook up the wires but it's really vague in the sense that it only identifies the wires by color and not by what the connection is (ground, power, etc). The manual indicates I should hook all white wires together and the black control wire to the black junction box wire, and then connect the red control wire to the black lamp wire. It also says I can optionally connect the load across the white and red wires.
My problem is that when I opened the wiring on the house, all I see are a single black and single white wire connected together with a single green wire not connected together:
Any help with wiring this would be very appreciated! Thanks!
serratedauto is offline   Reply With Quote
Old 11-24-2012, 09:33 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Who removed the sensor?
The way it is wired now would bypass a sensor.
Old 11-24-2012, 09:34 PM   #3
Right. The sensor was removed a while ago (don't ask by who), but yes right now it does work without the sensor. I want to wire the sensor back in the loop.
Old 11-24-2012, 09:39 PM   #4
jbfan's Avatar
Rewards Points: 478
Does the sensor have 2 or 3 wires, not counting the ground or green wire?
Old 11-24-2012, 09:40 PM   #5
The sensor has 4 wires (red, green, white, and black).
[edit] saw the last part of your post, it's 3 wires without the green [/edit]
Old 11-24-2012, 09:40 PM   #6
joed's Avatar
Rewards Points: 12,872
It appears your new sensor needs a neutral where your old did not. I think you need a different sensor that only needs two wire and no neutral.
Old 11-24-2012, 09:41 PM   #7
jbfan's Avatar
Rewards Points: 478
The current wiring you have in the box will not work.
You need a hot wire and a neutral to feed the sensor, then a wire back to turn on the light.
Old 11-24-2012, 09:49 PM   #8
Then I'm confused because this was the wiring that was installed by the contractor. Did Zenith change their sensors with new wiring since this was originally installed 8 years ago?
Old 11-24-2012, 09:53 PM   #9
jbfan's Avatar
Rewards Points: 478
Maybe, maybe not.
The only way it could have worked with the current wiring like this would be an illegal installion.
Old 11-25-2012, 08:57 AM   #10
joed's Avatar
Did the old sensor have the same three wires?
Old 11-25-2012, 09:34 AM   #11
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Judging by the loose MC in the garage, I am betting that the original installation illegally used the ground for something other than what it was intended for.
The Following User Says Thank You to k_buz For This Useful Post:
jbfan (11-25-2012)
Old 11-25-2012, 10:03 AM   #12
JuzRick's Avatar
K_Bus: to me it looks as if serratedauto has a hot with leg(for operating a switch)on that line.. being there's that's only single line coming out vs two( 1 for the hot feed.. the 2nd for the switch to the light). In that switch box in the attic there's the possibility that the neutral is tied in from the main feed coming in as a hotfor the switch to control the lights.
In the case.. the new light should operate just the same... once serratedauto following the diagram to connecting the wires in place. Unless Serratedauto dont want the light(s) controlled by the existing switch in the attic, the same wiring will operate the light. I've did an install similar to that format. And that all is was! AGAIN::: every scenario is different...
JuzRick is offline   Reply With Quote
Old 11-25-2012, 10:09 AM   #13
k_buz's Avatar
You are not following. What you see is existing. ALL motion detectors I've installed have needed a neutral to operate the electronics inside the detector. There isn't the correct wiring available in the existing set up to install a new motion sensor...unless they used the ground illegally.
Old 11-25-2012, 10:17 AM   #14
JuzRick's Avatar
K_Buz: if how the electrician tied the line unto the switch in the attic(as to what is shown).. that neutral serves as they hot.. and the black is the switch leg(controlling the light).. "a verse hot"- is what im applying. I've seen it before done that way. Also wired a few that way vs pulling more wire(depending on the task of the job).
Old 11-25-2012, 10:21 AM   #15
JuzRick's Avatar
K_Buz::: I got it now. Different setup... totally!!!!
Dual wiring for motion sensor security light ent Electrical 2 09-14-2011 02:00 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 08:52 AM
Dual-brite motion detector light to operate second light? downunder Electrical 2 09-10-2010 03:48 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 10:39 PM
