Yup, Another Subpanel Wiring Question! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2008, 11:21 AM   #1
Yup, another subpanel wiring question!
Ok guys, learning a lot from you all. So I have my detached garage with a sub panel in it. It has two hots and a neutral from the main panel. No ground run. (I know this isn't 2008 code as I have learned on here). At the main panel, the ground and neutral bars are connected by the bonding screw (Cutler-Hammer) and it has a grounding wire going to a ground rod.
At the subpanel, the set up is the same. The ground and neutral bars are connected via the bonding screw and a grounding wire running to a grounding rod.
So, is this correct? I have read so much on here about the 4 wire feeds, but very little on the 3 wire feeds. Thanks for any answers.
737Pilot is offline   Reply With Quote
Old 12-17-2008, 11:27 AM   #2
Rewards Points: 2,350
Yes this is correct, as long as there are no other metallic paths back to the house. This can be a metal water line, or phone or tv cable.
Old 12-17-2008, 12:25 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yep.... should look like this image
Old 12-17-2008, 02:07 PM   #4
Thanks guys...I do appreciate the answers. My panels look just like that diagram Stubbie posted.
Question on generator wiring mdalli Electrical 35 10-05-2011 08:45 PM
Older wiring question... PirateKatz Electrical 8 11-25-2008 11:11 AM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
