Your Preferred Method Of Cutting Holes For Boxes In Plaster Latt - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 09:43 AM   #1
your preferred method of cutting holes for boxes in plaster latt
What is your preferred method for cutting holes for old work boxes in plaster latte walls? Which tool do you use?
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
I am not an expert and don’t claim to be, these are just my views and opinions.
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
silversport (03-06-2012)
Old 03-06-2012, 09:47 AM   #2
Rewards Points: 13,712
Ossilating tool with a diamond blade, or a Roto Zip with a tile cutting blade.
Old 03-06-2012, 10:17 AM   #3
Ravenworks's Avatar
A+++
"latte" is always a treat, if you are using the boxes with the flip out tabs they won't have enough depth,I think they only open to 3/4"
Ravenworks is offline   Reply With Quote
Old 03-06-2012, 10:24 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Rotozip and longer screws for the old work box if needed.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-06-2012, 11:05 AM   #5
Longer screws is all I do also.
Often time when adding outlets to really old houses it's easyer to add them in the baseboards not the walls. Most old houses were framed with ballon walls so there's easy access under the house instead of having to fish wires inside the walls.
Old 03-06-2012, 08:34 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Either Rotozip or Fien tool will work depending on how strong the plaster et lath is but just go easy and expect a bit of dust.
Merci,
Marc
Plaster Walls, Holes From Switch Boxes Demo Dick Drywall & Plaster 3 12-11-2011 04:40 PM
Repairing Holes and Cracks in Plaster NewEnglandYank Drywall & Plaster 6 03-24-2011 12:35 PM
cutting holes in wonderboard Mike L Drywall & Plaster 2 08-31-2010 08:56 PM
Cutting holes in plastic J-Box jamiedolan Electrical 15 02-25-2009 05:58 PM
Plaster wall - cutting out an access hole, but how to replace it? Steelmesh Building & Construction 8 11-07-2008 09:40 AM
