-   -   your preferred method of cutting holes for boxes in plaster latt (http://www.diychatroom.com/f18/your-preferred-method-cutting-holes-boxes-plaster-latt-136159/)
Hardway 03-06-2012 10:43 AM
What is your preferred method for cutting holes for old work boxes in plaster latte walls? Which tool do you use?
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
I am not an expert and don’t claim to be, these are just my views and opinions.
joecaption 03-06-2012 10:47 AM
Ossilating tool with a diamond blade, or a Roto Zip with a tile cutting blade.
Ravenworks 03-06-2012 11:17 AM
A+++
"latte" is always a treat, if you are using the boxes with the flip out tabs they won't have enough depth,I think they only open to 3/4"
rrolleston 03-06-2012 11:24 AM
Rotozip and longer screws for the old work box if needed.
joecaption 03-06-2012 12:05 PM
Longer screws is all I do also.
Often time when adding outlets to really old houses it's easyer to add them in the baseboards not the walls. Most old houses were framed with ballon walls so there's easy access under the house instead of having to fish wires inside the walls.
frenchelectrican 03-06-2012 09:34 PM
Either Rotozip or Fien tool will work depending on how strong the plaster et lath is but just go easy and expect a bit of dust.
Merci,
Marc
