Your Opinion Please - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2009, 09:54 PM   #1
Rewards Points: 150
Your opinion please
Hey guys,
Anyone have any comments on these "wire nuts"?
Steelhead is offline   Reply With Quote
Old 02-03-2009, 10:16 PM   #2
Registered User
Termite's Avatar
I really like them and always carry an assortment of them in my electrical bag. They're pretty popular around here, even with pros. I like them because they're very DIYer friendly. They're also great when you're working in existing boxes and don't have enough slack to do a more conventional wire nut connection.
Old 02-03-2009, 10:33 PM   #3
Rewards Points: 150
That's exactly what I've found! Especially the short wires in the existing box situation. Some of these boxes....man, I can't figure out how they were able to get the wires on the receptacle!
Old 02-03-2009, 10:38 PM   #4
Simple, you wire up the outlet, pull the wire so the outlet is in the box, screw down the outlet. Run the wire to the next outlet & connect.
I didn't know those were available
They would have come in handy at my last house - short wires
Old 02-03-2009, 10:57 PM   #5
Rewards Points: 150
Ya, as soon as I posted my reply I thought the same thing. It still seems so weird to me to wire something like that, but I guess it probably happens more than I think by inexperienced homeowners. That's what's nice about this site - many will (hopefully) become more informed.
Old 02-03-2009, 11:42 PM   #6
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
I got stuck with short wires in a box recently, I am sure I could have used the wagos. I crimped on insualted butt splices and heat shrinked (used some butt splices that came with heat shrink insulation attached) them. They were really easy to use and felt very secure.
Anyway, back on topic, I used wagos for all my tempoary connections, anything I know I am going to be changing in a few days. I also used them in the florscent fixtures to make the connections between the small 16/18gage wire and the 12 gage feeding it. (but have now started to use insulated crimp-on's.
Never had a problem with the wagos's the way I have used them, but I will still be making twisted wire nutted (or crimped) connections for everything permanent..
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-04-2009, 07:22 AM   #7
I found a box with about 1 inch of wire left in it. Somehow they got a wire twisted on it and nutted it. They had to remove the clamp. Made more work for me, and caused me to loose my pliers in the attic.
rgsgww is offline   Reply With Quote
Old 02-04-2009, 09:18 AM   #8
Rewards Points: 900
I dislike the push-on terminals. They are not as secure as wirenutting (as long as the wirenuts are done right).
That is my opinion. They are UL approved, so I suppose they're OK.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-04-2009, 01:12 PM   #9
I'm sure the person thinks (overall) - "Hey I saved a couple feet of wire!!"
I like extra wire
Old 02-04-2009, 01:23 PM   #10
Registered User
Termite's Avatar
Opinions vary, and that is understandable. Some people refuse to use I-joists because they have always used 2x10's. Some people refuse to use PEX because they've always plumbed with copper.
However, I have never seen any empirical evidence that using stab-type connectors (Wago's, Ideal's, or otherwise) are any better or worse than a wire nut. So, the fact is that they are an acceptable/listed means of permanently connecting wires.
Old 02-04-2009, 01:47 PM   #11
RippySkippy's Avatar
KC, if I didn't know better I'd say our local building inspector had talked to you. I first saw these when I built our house...and he said the same thing and the fact that they were UL approved...he said go for it. I did use them in some locations...they worked well.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Wanted: Second opinion on radiant floor/boiler hookup drh HVAC 4 01-16-2010 08:41 PM
Opinion needed about changing kitchen faucet chris_p Plumbing 11 02-01-2009 10:39 PM
Color opinion for front porch rails and pillars? Beth777 Painting 6 07-14-2008 11:14 AM
Need opinion on Subfeed ANDYHD Electrical 2 03-12-2008 12:46 PM
What is your opinion on Goodman units? TomClarkInLubbock HVAC 3 08-16-2007 05:38 PM
