Yikies - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2011, 07:48 PM   #1
Yikies
This worked for 28 years.
Hourglass52 is offline   Reply With Quote
Old 05-08-2011, 08:05 PM   #2
I=E/R
a7ecorsair's Avatar
It could use a little freshening up
a7ecorsair is offline   Reply With Quote
Old 05-08-2011, 08:08 PM   #3
Mad Scientist
That picture's a little small, but aside from the ancient rag-wrapped SE cable, I think I see the concentric neutral extended by "splicing" it to a twisted bundle of aluminum wires, using a loop of copper wire as some obscene sort of twist-tie. Is that it? Because if so, holy !
Last edited by McSteve; 05-08-2011 at 08:12 PM. Reason: Whatever that is, it ain't splicing...
McSteve is offline   Reply With Quote
Old 05-08-2011, 08:32 PM   #4
Missouri Bound's Avatar
...you have been lucky
Old 05-08-2011, 08:38 PM   #5
The crappy splice worked because they only ran a few lights in the building. The building flooded this winter from a broken pipe. When the cleaning company came in and ran their huge dehumidifiers it started smoking. I don't know why the copper wire and aluminum didn't react and corrode.
It looks like SEU spliced to a piece of triplex wire.
Old 05-08-2011, 09:14 PM   #6
" Euro " electrician
frenchelectrican's Avatar
If that is part of the SE cable that denfentaly need to be replace anyway.
You are lucky so far you did not get the conductor catch on fire yet.
Merci,
Marc
Old 05-09-2011, 05:06 AM   #7
Not my mess.
This is a panel I saw when I was there to estimate the drywall and finish work. The other thing you can't see is that there was a small bathroom sink 3 feet below the panel.
The owner asked me if I thought it should be moved. They are going to rehab the place to be a studio apartment. { I thought (SURE, just get your hack to move it to the left about 3 feet into the shower)}
I told them to call a licensed electrician because the whole place will have to pass inspection to get a CO.
Crazy stuff.
Old 05-09-2011, 07:38 AM   #8
Learning by Doing
Leah Frances's Avatar
Wow. No, wait. Just Wow.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
