Yet Another Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 10:42 AM   #1
Rewards Points: 672
I have an outlet that the circuit branch terminates in (wire coming in and ending). I want to extend this wire along the wall to two new sconces. Access can not be gained from the floor above or below. How would you do this? Would you just cut a channel in the drywall (me 1/2" drywall and 1/2" plaster), insert the wire and patch? I maybe have 10' to go. What happens when you come to a 2x4?
B
Beepster is offline   Reply With Quote
Old 12-17-2012, 10:53 AM   #2
Rewards Points: 2,516
You notch it or drill a hole thru it. If you notch it you need to install a nailing plate over the notch
hammerlane is offline   Reply With Quote
Old 12-17-2012, 11:04 AM   #3
Rewards Points: 672
It's that simple? There isn't any better way?
Would you cut the channel the whole 10 ft, or just cut a channel at each 2x4 where you notch and fish it through the wall between the 2x4s?
B
Old 12-17-2012, 02:40 PM   #4
Rewards Points: 320
Cut as little as possible and fish what you can. Less patching is always better.
teamo is offline   Reply With Quote
208V/3 Phase Wiring Question efalcon1 Electrical 12 09-28-2012 11:22 AM
Outdoor Wiring Question OKDrew63 Electrical 30 08-14-2012 11:25 PM
Adding 2 outlets in the middle of a series of outlets - wiring question Evan55 Electrical 7 06-14-2012 09:43 AM
Attic wiring question everyman Electrical 4 07-07-2009 09:47 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
