Yet Another 3 Way Circuit Question! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 08:13 PM   #1
Yet another 3 way circuit question!
Hello all,
I am in the process of renovating my basement, and have a 3 way circuit question for anyone interested.
I have power coming to the first 3 way switch with 14-2 (black to common). 14-3 leaves the switch and travels to a box with two switches, the second 3 way , as well as a separate 3 way for another pair of lights. Can I power the second 3 way pair of lights with the 14-3 coming into the box, or do I have to run a separate power source to the box?
Thanks to those that respond for their time! This forum has been a great resource for me (Canada's TOP 10 worst DIYer') during my reno!
M.
sirkeen is offline   Reply With Quote
Old 07-27-2009, 09:10 PM   #2
dSilanskas's Avatar
No you can't do it. You still need a neutral at the second box for the other three way.
dSilanskas is offline   Reply With Quote
Old 07-27-2009, 09:27 PM   #3
Thank you!
Old 07-28-2009, 11:05 AM   #4
Rewards Points: 128
Yes, you can. But you have to reverse how the switch loops works. Right now the power is in the first switch box, and the switching wire is in the second switch box. Reverse this and you can use the same hot for both 3 way circuits.
This could be difficult, or very difficult to do. You may want to take the advice of dSilanskas above.
J. V. is online now   Reply With Quote
Old 07-28-2009, 11:54 AM   #5
Remodeler
adpanko's Avatar
Rewards Points: 150
You'd have to run a 14/2 between the two boxes, in addition to the existing 14/3.
adpanko is offline   Reply With Quote
Circuit Size Question techinstructor Electrical 12 06-28-2009 08:24 AM
Electrical Circuit Doesn't Work kcrossley2 Electrical 11 05-21-2009 04:22 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
