Yes Another Grounding Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2008, 03:40 PM   #16
Licensed Electrician
Originally Posted by Speedy Petey View Post
This current can be through a human or simply flowing into the earth. The GFI doesn't care.
I don't want to sound like I'm splitting hairs, but it needs to be remembered that there is a difference between GFCI and GFI.
GFCIs are for protection of personnel and trip at a low value (<5mA?). GFIs are used for the protection of equipment and trip at a higher current....30mA, I believe.
Speedy's comment is right on about the current flow through a human or into the earth. The GFCI doesn't know and doesn't care; in fact it pretty much operates on an assumption. It looks for an unbalance between the hot and neutral. If it senses that unbalance, it trips. The assumption is the current is going to ground because there is no where else for it to go. That's why you don't need a grounding conductor hooked up to a GFCI outlet for it to operate.
Tuckahoe Sparkplug is offline   Reply With Quote
Old 10-21-2008, 08:11 PM   #17
Rewards Points: 2,350
Actually, GFI and GFCI are the same thing. The term, as it is used in the code, is "Ground Fault Circuit Interrupter", but alot of electricians, especially those east of the Mississippi, drop the "Circuit" out of it, and just say GFI. If I'm talking to another electrician, I would say GFI. If I'm talking to a customer, or DIY'r here, I say GFCI.
What you are referring to above is "Ground Fault Protection of Equipment", or GFPE. The GFCI in the kitchen and bath is "Ground Fault Protection of Personnel". An electrician would call either of these a GFI.
Old 10-21-2008, 08:51 PM   #18
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Tuck, InPhase is right on with his explanation of GFCI and GFPE.
Speedy Petey is online now   Reply With Quote
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 08:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 04:14 AM
