Yard Light Ground... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 12:31 AM   #1
Hi Everyone,
I have a acerage where I installed a city style street light. I think it is 28 feet tall and it sits upon a metal 'screw in' base that goes about 8 feet into the ground cased in concrete.
Inside the access panel of the light there is a ground wire and I have connected my underground wire to the pole wire.
My question is: Being that this light pole is probably at increased risk for a lightning strike... how should I connect the ground wire to the light itself?
and should I connect (tie in) the ground wire that is connected to the pole?
Thanks in advance.
Dean
dean830 is offline   Reply With Quote
Old 06-09-2011, 12:53 AM   #2
Learning by Doing
Leah Frances's Avatar
What's it made of?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-09-2011, 01:09 AM   #3
Originally Posted by Leah Frances View Post
What's it made of?
The pole itself is galvanized steel I believe - And bolted to the base.
Old 06-09-2011, 01:20 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Normally with the larger luminaires I genrally install a ground rod and use 16mm≤ ( #6 awg ) conductor from ground rod to the luminaire post then bonded to the grounding { typically } green conductor.
But when you hook up the 16mm≤ to the post becarefull with drilling you do not need to make any larger than 8mm diamiter hole { IIRC they should be about quarter inch hole } and bolt it and have a brass or copper lug that where the 16mm≤ conductor will be tied into.
( Unforeteally I don't have the photo how this work but I know I did have the old photo somewhere in my second home in Wisconsin due I am living in France now )
Merci,
Marc
Old 06-09-2011, 01:41 AM   #5
Thanks! I will add a ground rod and connect it to the poles ground wire that is already attached. What do you suggest I do with the ground that is coming from my panel? Would lightning voltage feed back through to my panel if connected?
Old 06-09-2011, 01:45 AM   #6
The ground conductor you will tie them together as I mention about the lug connector and unforetally it will be bonded together and when the lighting strike it will spread out a bit it will feed back thru the panel it the same way if the lighting hit the POCO lines and they will lighting arrestors on the post which it is a common item.
Also I will suggest to get a whole house surge supressor as well that will help to reduce the amout of lighting damage or serious voltage surge to protect the system.
Merci,
Marc
Old 06-09-2011, 01:58 AM   #7
Sounds good. Thanks for the comments. I already have a whole house surge protector at the panel so I should be protected to some extent. Can't have too many ground rods!
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
dusk to dawn yard light redoak Electrical 6 12-15-2010 08:32 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 10:03 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
