Old 02-01-2010, 03:45 PM   #1
Y-socket adapters in the garage - safe with CFLs?
My garage has two Type A ceiling sockets powered off a single switch. I'm currently using two 60W equivalent CFLs, each with a 13 watt current draw. The garage is a bit dim to work in, and I thought of a simple way to double the light output: I'd like to run two 13 watt CFLs (60W light equivalent) per socket using a Y adapter - so four lights total across the two sockets. Are "Y" socket adapters like this one safe to use with CFLs?
http://www.amazon.com/Leviton-128-I-...ref=pd_cp_hi_1
I don't think there's any increased fire risk if I go with good quality "Y" adapters (e.g., UL listed, Leviton brand, not made in China, 660W max draw). Each of the ceiling sockets is currently rated to handle 60W incandescent bulbs (so 120W total on the circuit). With four CFLs plugged into two Y adapters, the current draw shouldn't exceed 13W x 4, or 52 watts total (26 watts per light socket).
Is there any reason this wouldn't work? Is there anything about CFLs that make them incompatible with Y socket adapters? I know you're not supposed to use CFLs with "dusk to dawn" light sensor adapters, and was wondering if there's anything similarly weird that applies to Y socket adapters. I don't think there's an issue, but figured it couldn't hurt to check with you guys before attempting it.
Thanks!
TitaniumVT is offline   Reply With Quote
Old 02-01-2010, 05:39 PM   #2
Xtreme DIY'r
As long as everything is rated for the wattages used you should be OK
Old 02-01-2010, 05:45 PM   #3
Thanks for the confirmation, Dave. I appreciate it!
Awesome avatar picture, by the way. :-)
Old 02-01-2010, 06:11 PM   #4
Wire Chewer
Red Squirrel's Avatar
While you're at it, get the 100w equivalent ones. They make a HUGE difference too. Sadly they seem a bit harder to find in large quantities. I find it hilarious when I see a single CFL in a HUGE plastic packaging. That kind of defeats the whole purpose of going green.
Old 02-02-2010, 12:16 AM   #5
That's a great suggestion, Red Squirrel. Thanks. I stopped by Ace Hardware on my way home and picked up a couple of the Y socket adapters ($6.50 with tax for 2). This simple, inexpensive solution has already brightened up the garage a lot with 60 watt equivalent CFL bulbs.
I'm going to see if I can pick up some 100 watt equivalent CFLs as you suggest. That should be more than bright enough for my needs.
Old 02-02-2010, 12:19 AM   #6
Thanks!
There are now available "dusk to dawn" light sensors that are specifically designed to work with CFL's. As well as CFL's designed for outdoor use. I changed a couple of my workshop's exterior lights over to such a setup.
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 08:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Is 1000 watt power supply unit safe on home socket? darsunt Electrical 11 07-13-2009 10:41 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
