Xpelair - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 05:00 PM   #1
Xpelair
I have a Xpelair DX100t and have until recently had installed on it a red led light which indicates when the device is switched off (necessary due to having a timer on it). As the led has stopped working I want to replace it but do not know what led/resistor I need to buy. As their is all kinds of resistors, can anybody please tell me what I require.
nigelgoodwin is offline   Reply With Quote
Old 04-04-2009, 05:48 PM   #2
as seen on tv
Rewards Points: 150
resistor color code? bbroygbvgw
qbert is offline   Reply With Quote
Old 04-04-2009, 11:13 PM   #3
Union Electrician
goose134's Avatar
Niiiice.
goose134 is offline   Reply With Quote
Old 04-04-2009, 11:23 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Resistor color code also known as black, brown, red, orange, yellow, green, blue, violet, gray, white. Black=0, white=9. First two bands are actual numbers, third band is number of zeros to the right of the first two, fourth band is % tolerance.
To get the proper resistor, we'd need to know the voltage applied to the LED. An LED is basically a short circuit, and needs a resistor in series with it to limit current.
Rob
micromind is offline   Reply With Quote
Old 04-04-2009, 11:49 PM   #5
Why don't you replace the LED and use the existing resister?
hayewe farm is offline   Reply With Quote
Old 04-05-2009, 11:50 AM   #6
Usually red indicating LEDs are ~2v forward voltage at 20 mA.
Old 04-06-2009, 09:24 AM   #7
Xpelair
Rob
The voltage is 240 and I believe the ampage of the Xpelair is 5.
