X-mas Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 10:16 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
X-mas lights
I have a lighted moose outside, and on one side the bulbs look like they are running at about 10% power, There are a few within these lights , that are fully lit, I have tested them all out, replaced the bad ones and replaced all of the little fuses.
Any suggestions
Barry
Barry J is offline   Reply With Quote
Old 11-28-2011, 02:27 PM   #2
Rewards Points: 1,514
IF you replace some of the light bulbs and the new ones don't precisely match the old ones in terms of current draw (not easy to predict in advance) then some will be brighter than others. Usually the ones that are brighter will tend to burn out more quickly compared with having perfectly matched bulbs to begin with.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 07:23 PM
