Wrong Starter For Fluorescent Light - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2009, 06:09 PM   #1
Wrong Starter for Fluorescent Light
I have a twin fluorescent light fitting in the kitchen.
I replaced the starter on one side but the starter was 100-125 Watt and the tubes were 70Watts.
It worked for 2 days then the lighting trip went up. It has not worked since.
The other side is fine and works as normal so we have one working tube.
What usually happens of you put a heavy starter into a lighter tube?????
charlie11051980 is offline   Reply With Quote
Old 02-17-2009, 11:30 PM   #2
Idiot Emeritus
Rewards Points: 1,492
The starter in a fluorescent fixture is there to cause current to heat up the ends of the tube for a few seconds, then cause the high voltage to light the tube.
If the starter was too big, it would either burn the tube out, or burn up the ballast. Pretty much a toss-up as to which one.
Try putting a known good tube and starter in the fixture that doesn't work. If it still doesn't work, the ballast is very likely bad.
Rob
micromind is offline   Reply With Quote
Old 02-18-2009, 12:03 PM   #3
Rewards Points: 204
Are you sure we are talking "starters" and not ballast's (transformers). New fluorescent fixtures very seldom use starters any more, if at all. The newer fixtures have rapid start ballast's in them and require no starter.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
