IS This Wrong? Romex Connector? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 01:02 PM   #1
Rewards Points: 81
IS this wrong? Romex connector?
My Juno IC22 can lights have spots for non-metallic (romex/NM) to go into the box, rather than using the knockouts and putting in clamps.
I ran across this picture on a home inspectors website saying that this practice is wrong. Please see his picture below...this is exactly how I am running my wires into the built in junction box at the light.
Is this wrong?
JeepNick is offline   Reply With Quote
Old 02-26-2012, 01:06 PM   #2
It is wrong and non code compliance
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 02-26-2012, 01:08 PM   #3
Code05's Avatar
Rewards Points: 1,104
Is there an internal clamp on the inside that you tighten down?
Code05 is offline   Reply With Quote
Old 02-26-2012, 01:13 PM   #4
Master Electrician
Rewards Points: 3,874
The only thing wrong is that the rectangular ko should be removed completely. The internal clamp secures the cable.
brric is offline   Reply With Quote
Old 02-26-2012, 01:14 PM   #5
Rewards Points: 81
Here is a picture of my actual setup...
Old 02-26-2012, 01:18 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Why not just use the round knock outs and some of these :
http://www.foxelectricsupply.com/Con...duct/nm94a.jpg
Journeyman Plumber
Old 02-26-2012, 01:20 PM   #7
Rewards Points: 13,732
I think I would have used one of these instead.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Hardway (02-26-2012)
Old 02-26-2012, 01:29 PM   #8
Code05's Avatar
Post #4 is your answer.
Old 02-26-2012, 01:29 PM   #9
Code05's Avatar
Smaller pic next time please.
Old 02-26-2012, 02:10 PM   #10
Master Electrician
Those connectors are fine also. Some of us must be concerned with production as well as costs.
Old 02-26-2012, 02:23 PM   #11
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Where does the ground wire connect to? I can't see with the picture.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-26-2012, 02:28 PM   #12
Master Electrician
Fixture has a ground wire riveted to the j-box
Old 02-26-2012, 03:01 PM   #13
Rewards Points: 81
Yea, in the second picture I posted (of my work) it appears the ground is going into the neutral nut. Its not. There is a separate nut with ground wires connected behind the neutrals and the wire is riveted
to the box as brric said.
Thank you for the input all. I've removed the knockout on the NM inlet and snugged up the built in "clamps."
Old 02-26-2012, 03:24 PM   #14
Rewards Points: 6,652
I would not listen to what the particular home inspector site you went to, says. Those in the trade, that are on here will tell you if it is correct, and post#4 is correct.
I can probably guess which HI site you are talking about, due to they tend to not like it, when those with experience in fields come on their site and tell them that they are incorrect on what they are telling people, along with the fact, that 99% on that site that I am guessing you got this from, are rookies at best, and I personally would not allow them to inspect my property.
The Following User Says Thank You to gregzoll For This Useful Post:
jbfan (02-26-2012)
Old 02-26-2012, 05:52 PM   #15
Code05's Avatar
It is kinda fun to go there and harass the HIs.
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
What's the name of this connector? dasgata Carpentry 7 11-03-2011 09:13 PM
OK To Bend A StrongTie Sheet Metal Hanger Connector? Gordo Burgess Building & Construction 5 10-12-2011 07:55 PM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
attach male connector to romex? cbzdel Electrical 4 05-12-2010 07:35 PM
