-   -   Wrong plug? (http://www.diychatroom.com/f18/wrong-plug-34735/)
alpercata 12-30-2008 08:15 PM
Wrong plug?
I am rewiring my furnace, which is currently hardwired. What I am doing is putting in plugs in place of the hardwiring so that I can pull the plug and then plug into my generator if the power should go out so that I will have heat and hot water. The furnace is on a 15 amp breaker so I am using a 15 amp plug. When I plug it in the breaker trips. Why would this happen? I checked for shorts and there are none.
Gigs 12-30-2008 08:29 PM
Is it on the same breaker it was on before?
Pictures might help if you have a camera.
Jim Port 12-30-2008 09:23 PM
Do it correctly and install a transfer switch and an emergency panel.
What you propose is not a Code compliant method.
Gigs 12-30-2008 10:10 PM
Why not?
Termite 12-30-2008 10:20 PM
Furnaces and water heaters are not cord and plug appliances, period. This is definately not a code-compliant wiring method.
A generator subpanel feeding the furnace, water heater, and whatever other circuits desired is the way to do this. With appropriate transfer gear that prevents backfeeding the service, the portable generator can be plugged into a dedicated receptacle "feeder" during a power outage.
What's being proposed is better than backfeeding the breaker with a generator, and therefore energizing the busbar of the panel and the entire electrical service. That is a great way to get a lineman killed when they think they're working on a dead line two blocks down the street.
InPhase277 12-30-2008 10:36 PM
Yeah, but it's probably not the electricity that kills him... It's the fall:laughing:. Ok. Bad taste?
Termite 12-30-2008 10:40 PM
Yeah, bad taste. :yes::laughing:
Honestly, in that situation he's pretty much dead before he hits the ground. :(
