Would You Reidentify To Save $$$ - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 10:40 AM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Would you reidentify to save $$$
HI;
I am going to need to run #6 for the hot tub and to the attic for my Kitchen sub panel. So I need a lot of #6 (each run about 70 feet X 4 wires = 560).
I could save $200 if I get a spool of 500' black and reidentify the other strands. I am pretty sure you can only reidentify 4# and larger.
I know it is a technical violation of the code (I know some here have said it is one of the most minor violations there is), but (if this was your house and your $) would you reidentify the wire for your neutral? Would you reidentify for your ground? I'd love to save the $200, but I really want to stay compliant with all the codes. So I have mixed feelings on the issue and was hoping for a bit of feed back.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-21-2008, 10:52 AM   #2
Rewards Points: 2,350
Originally Posted by jamiedolan View Post
HI;
Jamie
I would re-identify it, smiling the whole time. We can all thump a code book, but man, it is literally just a piece of tape on a wire. Me and the inspector would probably have to roll around scrapping in the mud about such a tiny tiny tiny issue. It really is a non-issue. Save your money.
Old 11-21-2008, 10:55 AM   #3
I have re identified #6 neutrals, but not grounds. Can't you use a #10 for your grounds. That would give you less than 500' for the #6's and 150' of #10. If you do it make sure you re identify at every box, junction, and device.
jerryh3 is offline   Reply With Quote
Old 11-21-2008, 11:17 AM   #4
I think so, Id have to look at the tables again.
rgsgww is offline   Reply With Quote
Old 11-21-2008, 07:42 PM   #5
Rewards Points: 508
Send a message via AIM to theatretch85
I would not use a black conductor and color it green, get an actual green conductor of the appropriate size (I believe either #10 or #8 can be used here).
Will this be in a metallic raceway or non-metallic (ie PVC)?
theatretch85 is offline   Reply With Quote
Old 11-21-2008, 07:46 PM   #6
DIY'er
jamiedolan's Avatar
3/4" EMT.
Jamie
Old 11-21-2008, 07:59 PM   #7
Anyone know the rationale behind not re-identifying? Not me. . .
Old 11-21-2008, 08:02 PM   #8
Alot of people mess up...nobody knows what the installer was thinking...just less confusion...
Old 11-22-2008, 11:42 AM   #9
Rewards Points: 246
Our local inspector allows re identifying #6 on subs ect.......Of course I asked him first.
I think the reasoning is that tape is not permanent.
Old 11-22-2008, 04:01 PM   #10
Better not tell that to 3M!
Old 11-22-2008, 05:38 PM   #11
And maybe somebody makes colored heat-shrink tubing for this purpose.
Old 11-22-2008, 06:17 PM   #12
the Musigician
DangerMouse's Avatar
70 feet X 4 wires = 560? last i checked it was 280.....? am i missing something? probly.....
DM
Old 11-22-2008, 06:36 PM   #13
DM
Two runs.
Old 11-22-2008, 06:51 PM   #14
the Musigician
ah, ok.... long day staring at these things removing virus' from client's machines....
DM
Best way to save money on project? PricelessDharma General DIY Discussions 5 01-20-2008 07:19 PM
Excavating my home to save a buck mikegeorge Building & Construction 5 02-27-2007 09:41 PM
