-   -   Would you reidentify to save $$$ (http://www.diychatroom.com/f18/would-you-reidentify-save-32332/)
jamiedolan 11-21-2008 11:40 AM
HI;
I am going to need to run #6 for the hot tub and to the attic for my Kitchen sub panel. So I need a lot of #6 (each run about 70 feet X 4 wires = 560).
I could save $200 if I get a spool of 500' black and reidentify the other strands. I am pretty sure you can only reidentify 4# and larger.
I know it is a technical violation of the code (I know some here have said it is one of the most minor violations there is), but (if this was your house and your $) would you reidentify the wire for your neutral? Would you reidentify for your ground? I'd love to save the $200, but I really want to stay compliant with all the codes. So I have mixed feelings on the issue and was hoping for a bit of feed back.
Jamie
InPhase277 11-21-2008 11:52 AM
Originally Posted by jamiedolan (Post 188177)
HI;
Jamie
I would re-identify it, smiling the whole time:thumbup:. We can all thump a code book, but man, it is literally just a piece of tape on a wire. Me and the inspector would probably have to roll around scrapping in the mud about such a tiny tiny tiny issue. It really is a non-issue. Save your money.
jerryh3 11-21-2008 11:55 AM
I have re identified #6 neutrals, but not grounds. Can't you use a #10 for your grounds. That would give you less than 500' for the #6's and 150' of #10. If you do it make sure you re identify at every box, junction, and device.
rgsgww 11-21-2008 12:17 PM
I think so, Id have to look at the tables again.
theatretch85 11-21-2008 08:42 PM
I would not use a black conductor and color it green, get an actual green conductor of the appropriate size (I believe either #10 or #8 can be used here).
Will this be in a metallic raceway or non-metallic (ie PVC)?
jamiedolan 11-21-2008 08:46 PM
3/4" EMT.
Jamie
Yoyizit 11-21-2008 08:59 PM
Anyone know the rationale behind not re-identifying? Not me. . .
rgsgww 11-21-2008 09:02 PM
Alot of people mess up...nobody knows what the installer was thinking...just less confusion...
J. V. 11-22-2008 12:42 PM
Our local inspector allows re identifying #6 on subs ect.......Of course I asked him first.
I think the reasoning is that tape is not permanent.
Wildie 11-22-2008 05:01 PM
Better not tell that to 3M!:)
Yoyizit 11-22-2008 06:38 PM
And maybe somebody makes colored heat-shrink tubing for this purpose.
DangerMouse 11-22-2008 07:17 PM
70 feet X 4 wires = 560? last i checked it was 280.....? am i missing something? probly.....
DM
jerryh3 11-22-2008 07:36 PM
DM
Two runs.
DangerMouse 11-22-2008 07:51 PM
ah, ok.... long day staring at these things removing virus' from client's machines....
DM
