Would There Be Any Codes Against This? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2010, 11:00 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Would there be any codes against this?
I am planing out the power for my server rack, and instead of having a couple outlets, then using a PDU, I want to completely illiminate the need for any form of power bar/PDU and just plug straight into outlets.
What I would do is have a small wall of sorts on both sides of the rack, and it would pretty much be filled with receptacles. They would be split off across several 15 amp circuits and some of them would have an inline UPS (would use a male socket as the jumper point, as suggested in another thread). So say, a 2x6, with two 2x4's on each side, and like 30 duplex plugs in between installed in proper boxes like I would on any normal wall. While this is quite custom, I don't see anything code wise that would make it wrong. Would it be fine? Is there a max number of outlets in a given square footage area, or something of that sorts? IMO I think this will be safer then anything as there will be no power bar or "splitting" type devices involved, it will all be done in the electrical system which is less prone to being moved around such as power bars and extension cords, splitters etc.
Old 12-24-2010, 01:47 AM   #2
Mad Scientist
It's unconventional, but I can't really think of anything about it that would be illegal. That said, some sort of plugmold might give you a cleaner appearance than a whole mess of outlet boxes. Also, if you really have that much gear, you might want to think about getting a larger UPS which is meant to be hardwired into a circuit, instead. One of the ones that needs a 30-amp circuit and twistlock receptacle. Usually starting at around the 2200KVA level there will be hardwire kits available, at least for APC products.
McSteve is offline   Reply With Quote
Old 12-24-2010, 06:04 AM   #3
Rewards Points: 1,192
At that level,you need your own power plant!
bobelectric is offline   Reply With Quote
Old 12-24-2010, 08:07 AM   #4
Just call me Andrew
Rewards Points: 1,020
The only thing I'd suggest is some Vitamin D supplements to make up for your lack of exposure to sunlight!
Andrew
secutanudu is offline   Reply With Quote
Old 12-24-2010, 08:10 AM   #5
joed's Avatar
Rewards Points: 12,918
The only limitations are 12 receptacles per circuit and box fill requirements.
I just saw Mike Holmes rip a setup like that out of a house on his Holmes Inspection show.
Old 12-24-2010, 08:13 AM   #6
joed's Avatar
That has to be a mis type. We run a 63,000 sq foot office on 160KVA. 2200KVA is 2.2 megawatts.
Old 12-24-2010, 10:15 AM   #7
Mad Scientist
Haha, yes, I definitely meant 2200VA, not KVA. Shouldn't try to communicate after 0100 in the morning.
Old 12-24-2010, 12:26 PM   #8
Wire Chewer
Rewards Points: 126
For now I'll have a 1kva unit but will be adding more in the future. I am selective about what I actually protect, rest is just surge protected and if power goes out then it goes down. I don't have much gear yet, but I always want to have room for expansion.
My next goal is to invest in green energy LOL.
Bedroom window egress codes drtbk4ever Remodeling 21 02-27-2013 02:21 PM
Carrier Weathermaker SXi Codes 41 and 44 Knight78 HVAC 5 11-12-2010 06:18 AM
Getting around building codes; shotcrete; LOW cost shotcreteman Building & Construction 28 10-15-2010 05:40 PM
Fault Codes on Bosch Oven alex_ny Appliances 3 06-15-2009 07:17 PM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 07:15 AM
