Would This Be Allowed By Nec Code? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 11:58 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
You did not create a safety hazard with the tape.
You can remove it or leave it.
The Following User Says Thank You to jbfan For This Useful Post:
feralfreak (10-21-2012)
Old 11-06-2012, 02:45 AM   #17
i carved this sword
feralfreak's Avatar
Rewards Points: 109
ive been having thoughts of adding a switch to control a shoplight overhead instead of always having to flip a switch on a surge protector so i took the mockup i made earlier and added a switch to it for more instruction, did i do it right? i left the cable to the right in the pic because i didnt want to mess with that part, i figure the outlet after a switch would be the end of the circuit, i cut the wires under the red nut to a half inch and lined them up even, then twisted them until the white part twisted, used a holed green nut for the ground and put the wires on in the direction of the screws tightening, what i did in the switch wiring here i learned from youtube but i wanted professionals to see if i did this right.
feralfreak is offline   Reply With Quote
Old 11-06-2012, 06:16 AM   #18
Rewards Points: 1,500
Originally Posted by feralfreak View Post
i wasnt sure if i should push/fold the wires into the box or pull the excess out back through the entry holes, but i thought if i ever have to change it it might be best to tuck them back in, was that right?
Approximately 1/4 inch of cable jacket should protrude into the box past the clamp or finger. For a wire fastened outside the box and entering through an oversized hole at an angle, have at least 1/4 inch of cable jacket entering the box all the way (past the farthest lip of the hole).
Old 11-06-2012, 06:47 AM   #19
To be to code the neutrals shall be pigtailed....MWBC...or if this is a switch recept.(fixed it)
Bobka is offline   Reply With Quote
Old 11-06-2012, 08:19 AM   #20
jbfan's Avatar
Rewards Points: 400
Originally Posted by Bobka View Post
To be to code the neutrals shall be pigtailed....loadside no... (whites) tied if not you could float a nuetral...if you lose a load side (black) nothing happens Cept you
Power....lose a neutral..things smoke
Neutrals are only required to be pigtailed on a MWBC.
I agree it is a better thing to pigtail, just not a requirement.
Speedy Petey (11-06-2012)
Old 11-06-2012, 04:04 PM   #21
agree aswell....thought he was spliting the recept for a switched recpt....FWIW I always pig my nuetrals...
Old 11-06-2012, 04:12 PM   #22
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Is this English?
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (11-06-2012)
Old 11-06-2012, 04:19 PM   #23
Originally Posted by Speedy Petey View Post
Is this English?
was from kindle this a.m. very hard to type on that thing...
The Following User Says Thank You to Bobka For This Useful Post:
Old 11-06-2012, 08:22 PM   #24
i carved this sword
feralfreak's Avatar
Rewards Points: 109
i probably should have taken the last cable off the mockup before posting it basically all im trying to do is see if that is the right way to go from the last line in a circuit(the cable on the left) to a switch and then out to an recepticle, i wanna see if i can understand how to do it.
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
error code 45 Turtle learner HVAC 2 01-10-2011 04:09 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
