Would 277v Lighting Circuit Be Considered MWBC - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 04:01 PM   #1
Would 277v lighting circuit be considered MWBC
Would 277v lighting circuit be considered MWBC?
5308jrc is offline   Reply With Quote
Old 03-15-2010, 04:47 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
voltage has nothing to do with a circuit being part of a MWBC.
when you have 2 or more legs (or phases), using a common neutral, that is a MWBC.
Old 03-15-2010, 08:30 PM   #3
Rewards Points: 506
What does MWBC stand for?
jlmran is offline   Reply With Quote
Old 03-15-2010, 08:38 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Multi-wire branch circuit
Speedy Petey is online now   Reply With Quote
Old 03-15-2010, 08:39 PM   #5
If you have to ask such a question what are you doing messing with 277v???
Old 03-15-2010, 09:00 PM   #6
Master Electrician
Rewards Points: 3,920
Originally Posted by speedy petey View Post
if you have to ask such a question what are you doing messing with 277v???
amen.
brric is offline   Reply With Quote
Old 03-15-2010, 09:17 PM   #7
Rewards Points: 506
So the 'multi-wire' portion of 'MWBC' refers to the energized conductors only?
Old 03-15-2010, 10:37 PM   #8
Electrical Contractor
kbsparky's Avatar
277 Volts from a MWBC would involve using a 480 Volt source. Not exactly a DIY project.
-KB
Old 03-16-2010, 06:28 PM   #9
Rewards Points: 506
Huh? All 277 volt service originates from 480 volt service, irregardless of MWBC status or not, correct?
Old 03-16-2010, 06:55 PM   #10
I kinda think that was the point.
Old 03-16-2010, 06:56 PM   #11
I'm not really sure what you mean.
It refers to the circuit conductors, but not the equipment ground.
To be honest I have no idea how MWBC came to be used as the term for this.
Old 03-16-2010, 07:00 PM   #12
Rewards Points: 506
I'm simply making fun of what I think is an incomplete acronym. Why is a 120V circuit utilizing a 12-2 NM cable not considered a MWBC?
Old 03-16-2010, 07:08 PM   #13
I guess because only a single wire is using one neutral, not "multi-wires".
Old 03-16-2010, 07:11 PM   #14
Rewards Points: 506
I propose a new acronym. MWUONBC - multi-wires using one neutral branch circuit.
Old 03-16-2010, 07:56 PM   #15
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
A two wire with ground 277 volt branch circuit is no more a MWBC than a two wire with ground 120 volt circuit. You must have a neutral not a grounded leg to have an MWBC.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 08:26 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
