Working Out Ohms - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 11:19 AM   #16
Issue of clarifying Electrical terms & calculations.
Originally Posted by Yoyizit View Post
Digi-key probably has a relay with a high-impedance coil that may do this.
Otherwise you can have a low power relay driving a relay that can switch 240vac.
How much current can your 5v deliver [get spec's or measure it]? How many amps does your 240v [AC?] appliance draw? Is it a motor load or a lamp load?
Your 5v source may need the relay coil transient suppressed to keep the source from being damaged.
In all the beautiful calculations and formulae (reminds me of School), we seem to have forgotten one aspect of the power requirements. Is the coil of the (12V.) relay designed to run on AC or DC? If it is designed for DC It will not function without attaching a Rectifier and Capacitor (To convert from AC to DC and to "smooth" out the DC (Non pulsating)). Speaking of personal experience. (Now more than ever) Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 08-16-2009, 11:29 AM   #17
Originally Posted by madazz View Post
My ECM is a Environmental Control unit it monitors temp/humidity and controls a fan (240V) for cooling and a control output for a 240v co2 solenoid.
We need OEM spec's, schematics and links, for your ECM and the relay it will be driving, etc.
If the OEM went out of business, next best is you measure, using voltmeters, milliammeters and variable resistors.
This may take a while.
Old 08-16-2009, 10:23 PM   #18
The manafacturer wont give out the information/specs.
ill post a pic of it now, also i was looking at the relay they sell and on it it has a sticker ZPR-2401 i was thinking this means zero power relay ???
ill post a pic of that aswell.
Thanks Every one For All your help!!
looks like this is gonna be harder than i thought, as i dont have voltimeters, millimameters etc so thats no option.
all i can tell everyone is that its a 5VDC signal,
i dont know what sort of relay to use, weather i use ssr or a mech type ? if they make 5vdc mech types.
madazz is offline   Reply With Quote
Old 08-16-2009, 10:31 PM   #19
1st pic is op of circuit board the arrow points to the 3 wires . 1 wire is neg 1 wire is for Air con + and 1 is for Dehumidifier +. the 1 neg wire goes to both plugs.
2nd pic is the back 3 lines point to the 3 wires.
now u can see other white wire hats for the hand controller/screen thats how i change my settings.
Working out ohms-black-arrow.jpg   Working out ohms-blk-line-back.jpg   Working out ohms-img_0355.jpg
Old 08-16-2009, 10:45 PM   #20
now if this helps i can get a better camera and get some full shots of the board top and bottom let me know.
many many thanks to every one u have all been the best help!
this site is the best!
aaron
Old 08-17-2009, 12:11 AM   #21
Semi-Pro Electro-Geek
Rewards Points: 2,938
When in doubt, just use a solid state relay. An SSR that is rated for 3-32VDC input is virtually guaranteed to work properly from your 5V signal. You probably cannot operate a mechanical relay from that signal - it will not supply enough current, and it may damage the controller. A solid state relay will not have this problem. Just pick an SSR with a 3V minimum DC input, and a rated current/voltage that will handle your load, and be done with it. Fairly easy.
mpoulton is offline   Reply With Quote
Old 08-17-2009, 12:49 AM   #22
:thum bup:
THANK YOU THAT THE ANSWER I WANTED. I HAD THOUGH ABOUT USING A SSR BUT WANTED TO MAKE SURE I DIDN"T DAMAGE MY ECM.
THANK YOU ALL!!!!!!!!:thumbsup :
aaron
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 05:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 09:27 AM
