Working With HOT Wires ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2015, 10:48 AM   #1
Rewards Points: 140
working with HOT wires ?
i AM NOT going to do this. but i was wondering. if one had to work on live wires. what gloves would do the job ?
Fix'n it is offline   Reply With Quote
Old 07-31-2015, 11:03 AM   #2
Master Electrician
Rewards Points: 3,678
Linemen's. Liners with leather over glove.
brric is online now   Reply With Quote
Old 07-31-2015, 11:03 AM   #3
They make special gloves for this. Any electrical supply house should have them
jimn01 is offline   Reply With Quote
Old 07-31-2015, 11:26 AM   #4
Rewards Points: 2,350
For the most part, there is no reason to work a circuit hot. Obviously troubleshooting needs to be done hot sometimes, but repair and replacement does not.
I used to do work hot because I cared about how convenient it might be to a customer. But these days I don't care how many lights or computers need to be turned off, their convenience isn't work my life.
The Following 5 Users Say Thank You to InPhase277 For This Useful Post:
billtech (07-31-2015), Jim Port (07-31-2015), Oso954 (07-31-2015), ritelec (08-01-2015), stickboy1375 (08-01-2015)
Old 07-31-2015, 02:02 PM   #5
Civil Engineer
Rewards Points: 4,514
The post is pretty vague, and difficult to understand. "What gloves would do the job?" What job is this? Protect you from getting shocked in the event you touched a live wire while grounded? Your gloves will do nothing to protect your face from arc flash in the unfortunate event you create a fault, easy to do when working hot. If your real question is "What protective gear and training do I need to safely work on hot equipment", well the answer is a whole lot more than a pair of gloves. Start with live voltage training, move on to understanding arc flash protection, then plan on purchasing a lot of arc flash gear (expensive).
The short answer is that no DIY'er without special training and equipment should ever work hot. If it is essential that the work be done hot, you need a specially trained electrician for the work, with a lot more than a pair of gloves for protection.
The Following 5 Users Say Thank You to Daniel Holzman For This Useful Post:
billtech (08-02-2015), Colbyt (07-31-2015), Jim Port (07-31-2015), Oso954 (07-31-2015), ratherbefishing (07-31-2015)
Old 07-31-2015, 02:12 PM   #6
Oso954's Avatar
Rewards Points: 420
Electrical PPE also needs special care. Here is a brief article on it.
http://m.ecmweb.com/content/take-care-your-ppe
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 07-31-2015, 02:43 PM   #7
Idiot Emeritus
Rewards Points: 1,492
Depending on the type of hot work, gloves can actually increase the hazard, as can any other type of Personal Protective Equipment.
Every situation is different, blindly applying regulations to hot work usually results in increased hazard.
micromind is offline   Reply With Quote
Old 07-31-2015, 03:50 PM   #8
Licensed electrician
Rewards Points: 1,016
Protective gloves come in different voltage ratings. It is not a one glove works for all.
Old 08-01-2015, 08:26 AM   #9
Rewards Points: 140
ok, let me refrace this question. how thick of a material, rubber or leather, would it take to not get shocked by 120v ?
again, there is NO other motivation behind this question, take it at face value.
Old 08-01-2015, 10:39 AM   #10
Rewards Points: 3,396
Gloves………..
Like trying to talk with a mouth FULL of food.
ritelec is offline   Reply With Quote
Old 08-01-2015, 10:53 AM   #11
Rewards Points: 119
Refer to NFPA70e and ATSM D120
KStatefan is offline   Reply With Quote
Old 08-01-2015, 04:36 PM   #12
Oso954's Avatar
Rewards Points: 420
That's a dangerous question. You do not want to be working with minimum thicknesses. First thing to go wrong and you get zapped.
The 500v gloves are proof tested at 2500vac. (There is also a vdc test, but I do not remember the voltage.)
You want plenty of safety margin in your gloves or rubber sleeves, blankets,etc.
You need to remember when talking about 120v that if you have 2 legs, you are dealing with 240v.
Old 08-02-2015, 01:59 AM   #13
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
The direct answer is that a GOOD pair of dry leather gloves will generally protect you from 120v.
To be proper, you need a set of 1000v rated secondary gloves (rubber) and leather protectors.
But nothing can protect you from ignorance. There's much much more than gloves needed to keep you from getting shocked, flashed or electrocuted.
clw1963 is offline   Reply With Quote
The Following 2 Users Say Thank You to clw1963 For This Useful Post:
Jim Port (08-02-2015), micromind (08-02-2015)
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 10:08 AM
4 electrical wires twisted together? bluewolf General DIY Discussions 4 03-16-2014 07:42 PM
Two black wires and two white wires in a ceiling mshaw11 Electrical 6 07-11-2012 10:57 PM
Carrier 9200 Weathermaker not working markwells HVAC 1 09-27-2011 08:22 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
