Working Hot - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 09:44 PM   #16
eastcoastsparky's Avatar
Rewards Points: 150
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
The Following 4 Users Say Thank You to eastcoastsparky For This Useful Post:
electures (01-16-2013), mpoulton (01-16-2013), Speedy Petey (01-16-2013), stickboy1375 (01-16-2013)
Old 01-16-2013, 09:47 AM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by sammy37 View Post
My Grandfather passed away a couple years ago, he was 98. He was a top notch union electrician way back when and did some major commercial projects in his time.
I'm not going to tell you how he used to test live circuits but going on the subject of this thread, you can take a wild guess how. He was indeed a tough old guy!
Let me guess. Started by licking two fingers??
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-16-2013, 09:53 AM   #18
DIY staff
Rewards Points: 7,174
My question-----just how many breakers are there in the box? Is it that difficult to find which one turns off the circuit?
Old 01-16-2013, 10:09 AM   #19
Burn marks on the back of his hand?
64pvolvo1800 is offline   Reply With Quote
Old 01-16-2013, 10:20 AM   #20
Trucon01's Avatar
Rewards Points: 510
His alias alone disqualifies him from touching electrical
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 01-16-2013, 11:25 AM   #21
Special User
Rewards Points: 1,230
Originally Posted by dum1 View Post
I know i shouldnt work hot but i cant find the breaker
Can't find the specific breaker, or can't find the breaker box?
If you can't identify which breaker, just flick them ALL off.
If you can't find the breaker box, start at where the power comes into your house, where the meter is. If there's not a big switch or breaker box there, look on the opposite side that wall. There pretty much has to be a service disconnect within a short distance of where the power enters the dwelling.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-16-2013, 11:41 AM   #22
Never had a screwdriver slip off a screw you were screwing in?
Never had a wrench slip off a nut?
Have you always kept your balance while working on something?
(Cranking down on a nut, the wrench slips off the nut and you go flying...)
Accidentally grabbed something you should not grab to catch your fall?
That is the problem with working with live electricity. A tool or you slip - a wire slips out and springs back to touch you - you loose your balance and grab onto to something (without time to think) and ZAP!
These things happen to everybody I know who works with mechanical fasteners (screws, nuts, bolts). Best this not happen around live electricity!
If you have the option to turn off electricity before doing work (breaker, main, or have electric company turn off power), then that is the BEST option...
Billy_Bob is offline   Reply With Quote
Old 01-16-2013, 12:14 PM   #23
SuperJETT's Avatar
Rewards Points: 156
I know i shouldnt work hot but i cant find the breaker and im only changing a switch, how would i go about it. If i had di-electric boots would i be safe from shock. Will having the screwdriver on the hot wire and me touching the switch will i get a shock
If you have to ask this question, then you really shouldn't even be considering it, at all, nevermind the fact that when you have the luxury of being able to turn off power, you should.
SuperJETT is offline   Reply With Quote
Old 01-16-2013, 12:26 PM   #24
First you need to make sure someone with a youtube account and video camera are present.
wrongdave is offline   Reply With Quote
Old 01-16-2013, 01:15 PM   #25
Rewards Points: 4,796
Talk about your black comedies...
OK seriously, here is what you should do (I know you won't do it, but at least there won't be a class action suit against the forum members.)
1. Turn off breaker
2. Wear these gloves, especially since there's a good chance you didn't get the right breaker
http://www.highvoltagesupplies.com/s...eblue-1026.cfm
In case you were wondering, you wear both gloves at the same time. No, the orange ones go on first.
Touching 2 different electrical things with 2 different parts of your body (e.g. left hand and right hand) at the same time is one good way to die. Water counts as 1 "electrical thing". I'd avoid touching water even with your new gloves on.
jeffnc is offline   Reply With Quote
Old 01-16-2013, 01:20 PM   #26
By the way, definitely not.
Old 01-16-2013, 06:18 PM   #27
Semi-Pro Electro-Geek
Rewards Points: 2,938
OK seriously, here is what you should do...
The only thing he should be doing is turning off the main and testing to confirm it's dead before working on it. Or hiring an electrician.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-16-2013, 06:24 PM   #28
So you advise him to NOT wear gloves.
Old 01-16-2013, 08:13 PM   #29
Rewards Points: 240
Pick a time during daylight when there is plenty of light in the room where you will be working. Then turn off the main. You can change an ordinary light switch in ten minutes. It won't be long enough for the house to get cold, and it definitely won't be long enough for anything in the fridge to thaw. Yeah, you'll have to re-enter the time of day on the microwave oven afterwards. It's a small price to pay.
Sometime after you've changed the switch, get someone to help you isolate which circuit that switch is on. If you go through your entire panel and can't find the one that shuts it off, you may have a sub-panel somewhere that you don't know about. Or you may have a wiring problem, e.g., the circuit that the switch is on is being back-fed by another circuit.
fa_f3_20 is offline   Reply With Quote
The Following User Says Thank You to fa_f3_20 For This Useful Post:
mpoulton (01-17-2013)
Old 01-17-2013, 12:53 PM   #30
Yeah. What's the point? They're hard to work in, and he shouldn't be working on anything that isn't confirmed dead. Nobody wears gloves except for hot work, which he shouldn't be doing.
gas dryer not working bcw0801 Appliances 4 05-03-2011 05:11 PM
Water Filled Gas Furance Not working szym0n HVAC 1 02-21-2011 04:46 AM
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 10:05 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
