01-15-2013, 04:04 PM
#1
Working hot
I know i shouldnt work hot but i cant find the breaker and im only changing a switch, how would i go about it. If i had di-electric boots would i be safe from shock. Will having the screwdriver on the hot wire and me touching the switch will i get a shock
Sent from my iPhone using DIY Forum
01-15-2013, 04:11 PM
#2
Lic Electrical Inspector
Working hot
Shut the main off. It is not worth it and no professional is going to suggest otherwise.
All responses based on the 2011 NEC.
If you live in New Jersey click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . All other states click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
Please check with local, county and state officials as laws may vary.
Sizing motors To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online motor calculator To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . Online calculators To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. .
The Following 7 Users Say Thank You to electures For This Useful Post:
01-15-2013, 04:13 PM
#3
Working hot
But in theory would i get shocked
01-15-2013, 04:14 PM
#4
Licensed Electrical Cont.
Working hot
In theory you will be killed.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
01-15-2013, 04:15 PM
#5
Working hot
Really!!!Killed!!!
01-15-2013, 04:16 PM
#6
Working hot
How many times have Speedy Petey and Electures work hot
01-15-2013, 04:20 PM
#7
Electrical Contractor
Working hot
Maybe we have or have not worked hot, but no one will tell you it is ok!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following 4 Users Say Thank You to jbfan For This Useful Post:
01-15-2013, 04:26 PM
#8
Working hot
Maybe he has an early death wish
01-15-2013, 04:27 PM
#9
Licensed electrician
Working hot
Working hot even for a properly trained individual still has risks. OSHA has strict rules about live work allowances. Replacing a switch is not one of them.
01-15-2013, 05:56 PM
#10
Semi-Pro Electro-Geek
Working hot
If you don't immediately know the answer to that question without even thinking about it, then you have no business working hot. You are way under-qualified for this.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
The Following User Says Thank You to mpoulton For This Useful Post:
01-15-2013, 05:57 PM
#11
Working hot
I can tell you that working hot in a hospital ICU feeder from the emergency power auto transfer switch is one thing, working on a light switch in a residence that can easily be safeteed and locked out for five minutes is entirely another. Either way, it ain't worth it!
Buy some hot gloves if you must but I can tell you that 120v kills a bunch more people than all the rest higher voltages.
Don't be a DUMdead1. Kill it before it kills you.
The Following User Says Thank You to 64pvolvo1800 For This Useful Post:
01-15-2013, 06:04 PM
#12
Working hot
Good catch
01-15-2013, 09:58 PM
#13
Electrician
Working hot
Just because my dentist takes a drill to my teeth doesn't mean she is going to tell me in a few sentences on how to do it for I can fix up my friends cavity.
01-15-2013, 10:21 PM
#14
Working hot
Originally Posted by dahockiem3
Chuyên m?c : kiem dinh cau truc
Công Ty C? Ph?n Ki?m D?nh K? Thu?t An ToÃ*n ThÃ*nh Ph? - KÃ*nh chÃ*o quý khách hÃ*ng
Hotline: Mr. Phi - 086348723
Chúng tôi hân h?nh du?c gi?i thi?u d?n quý khách hÃ*ng d?ch v? kiem dinh cau truc. C?u tr?c lÃ* m?t trong nh?ng thi?t b? có yêu c?u nghiêm ng?t v? an toÃ*n lao d?ng vÃ* v? sinh lao d?ng. Du?c quy d?nh c? th? t?i Thông tu 32/2011/TT-BLDTBXH ngÃ*y 14/11/2011 hu?ng d?n ki?m d?nh k? thu?t an toÃ*n các lo?i máy, thi?t b?, v?t tu có yêu c?u nghiêm ng?t v? an toÃ*n lao d?ng.
T?i sao c?u tr?c ph?i du?c kiem dinh VÃ* quy trình ki?m d?nh c?u tr?c nhu th? nÃ*o?An toÃ*n lao d?ng trong v?n hÃ*nh c?u tr?c ra sao? Chúng ta s? xem xét d? hi?u rõ hon v?n d? nÃ*y.
T?i sao ph?i ki?m d?nh c?u tr?c:
Nhu dã nói trên, c?u tr?c lÃ* m?t trong nh?ng thi?t b? có yêu c?u nghiêm ng?t v? an toÃ*n lao d?ng vÃ* v? sinh lao d?ng. Do dó chúng ta c?n ph?i ki?m d?nh c?u tr?c.
Thông tin liên h? kiem dinh cau truc
Mr. Phi 0878425784
Công ty chúng tôi hi v?ng du?c h?p tác vÃ* ph?c v? quý khách hÃ*ng
Phuong châm c?a công ty : An toÃ*n - Hi?u qu? - uy tÃ*n
Hãy liên h? tr?c ti?p v?i chúng tôi d? du?c tu v?n tr?c ti?p vÃ* t?n tình, vÃ* gi?i dáp nh?ng th?c m?c c?a quý khách hÃ*ng. Cám on b?n dã xem bÃ*i vi?t nÃ*y, chúc b?n m?t ngÃ*y lÃ*m vi?c thÃ*nh công.
TAG: ki?m d?nh|ki?m d?nh an toÃ*n
Huh?
01-15-2013, 10:42 PM
#15
Working hot
My Grandfather passed away a couple years ago, he was 98. He was a top notch union electrician way back when and did some major commercial projects in his time.
I'm not going to tell you how he used to test live circuits but going on the subject of this thread, you can take a wild guess how. He was indeed a tough old guy!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
