Old 09-03-2007, 08:56 PM   #1
working with hard to bend wires?
I have some older outlets where the wire connections are single copper wires. I found it extremely difficult to remove them and even more difficult to twist them into the proper shape to replace them on outlets. It made what I thought would be an easy job take hours.
Does anyone have any tips on how to better handle these wires? I was working with needle nose pliers and a screwdriver.
darsunt is offline   Reply With Quote
Old 09-03-2007, 09:16 PM   #2
Electrician
I can't see neednose working to well to make a loop in wire but should work because you should have either #14 or #12 in the wall.
When i do this I use my strippers, they have two little holes that I put the end of the wire in and twist them around. I have no clue what these holes are for but they work well for what i use them for.
darren is offline   Reply With Quote
Old 09-03-2007, 09:23 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
A needle nose should work fine. Use what makes you most comfortable.
That is EXACTLY what those holes are for. I use them too.
Old 09-03-2007, 09:39 PM   #4
The wires are extremely stiff. I was able to bend them, but if the loop was not the correct shape it was difficult to unbend them and rebend them correctly. Also I had to cut and restrip one wire because after a couple of attempted correction the wire collapsed at the bend point. Didn't help that there was hardly any space to work with.
Perhaps these difficulties are the norm?
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
lighting circuit not working Too many wires! darrenbooy Electrical 12 05-10-2007 11:58 AM
Running wires mt232 Electrical 4 03-22-2007 09:02 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
