-   -   working with hard to bend wires? (http://www.diychatroom.com/f18/working-hard-bend-wires-11251/)
darsunt 09-03-2007 07:56 PM
I have some older outlets where the wire connections are single copper wires. I found it extremely difficult to remove them and even more difficult to twist them into the proper shape to replace them on outlets. It made what I thought would be an easy job take hours.
Does anyone have any tips on how to better handle these wires? I was working with needle nose pliers and a screwdriver.
darren 09-03-2007 08:16 PM
I can't see neednose working to well to make a loop in wire but should work because you should have either #14 or #12 in the wall.
When i do this I use my strippers, they have two little holes that I put the end of the wire in and twist them around. I have no clue what these holes are for but they work well for what i use them for.
Speedy Petey 09-03-2007 08:23 PM
A needle nose should work fine. Use what makes you most comfortable.
That is EXACTLY what those holes are for. I use them too.
darsunt 09-03-2007 08:39 PM
The wires are extremely stiff. I was able to bend them, but if the loop was not the correct shape it was difficult to unbend them and rebend them correctly. Also I had to cut and restrip one wire because after a couple of attempted correction the wire collapsed at the bend point. Didn't help that there was hardly any space to work with.
Perhaps these difficulties are the norm?
