Working 20 Amp Gfci Tripping On High Amp Appliances - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 07:33 AM   #1
Working 20 amp gfci tripping on high amp appliances
I am running a vitamix, or a toaster oven, or a kitchen aid mixer on a 20 amp gfci that in replaced twice now, but it keeps tripping. The circuit doesn't trip, just the gfci does. I am never running all of these at the same time, only one at a time, yet just one of these appliances seems to always trip the outlet, and I have to reset it. The outlet is on its own circuit and is only feeding to one other outlet. I have checked the voltage coming from the wiring and everything looks good there. I have had to replace it because after it trips several times, it just stops working altogether. I don't see any moisture behind the wall in that spot. Does anyone have any advice because i feel like I have exhausted my resources trying to figure out the issue.
Spm8d6 is offline   Reply With Quote
Old 10-04-2013, 08:50 AM   #2
joed's Avatar
Rewards Points: 11,596
Defective appliances? Do they work on other GFCI circuits?
Disconnect the other receptacle from the LOAD terminals and see what happens.
Old 10-04-2013, 08:52 AM   #3
Resi EC
Rewards Points: 252
The GFCI was replaced, or the appliances?
The GFCI may be working properly, it may be a ground fault in the appliance.
You should have another GFCI protected circuit in the bathroom (depending on age of home) try using appliance there, see whether it trips or holds.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 10-04-2013, 11:01 AM   #4
Thanks for the responses. The appliances i have tried on other gfci outlets on other circuits in the kitchen and they work properly and I have replaced they gfci that is acting up a few times now so I don't know what it could be. I will try to disconnect the load receptacle later today and see if it is still acting up thanks for that advice. Maybe the load receptacle is bad and I just never really thought about it, I'll let you know if that changes anything. Thanks again.
Tags
electical , gfci , outlet
UPS tripping 20A GFCI in basement bensec01 Electrical 17 07-27-2013 04:35 PM
Is this a bad GFCI? Why isn't my smoke detector interconnection working anymore? WillK Electrical 8 03-31-2013 02:26 PM
gfci tripping can't find cause 1honus Electrical 10 01-03-2012 10:01 AM
Garage GFCI keeps tripping faromic Electrical 7 08-30-2011 11:45 PM
50 Amp GFCI tripping casnart Electrical 26 08-17-2011 05:12 PM
