It Worked Before! - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2012, 06:29 PM   #1
It Worked before!
Hi:
I replaced an old bathroom light fixture, with a new one and it worked fine. I took it down (to repaint). When I reinstalled it, the light will no longer shut off.
There are only three wires coming from the junction box for the light; two gray and a copper ground. The fixture has two white, a black and a copper wire. No matter what combination I try, it remains on.
I have three switches on the wall. The first one controls the ceiling light; the second controls the ceiling fan, which is in the light fixture that the first switch controls and the third switch appears to control nothing.
I put the light fixture back the way it was but it stays on no matter what switch I turn on or off.
Please help. What is the problem?
et
Eric D Thomas is offline   Reply With Quote
Old 09-15-2012, 07:40 PM   #2
Resi EC
Rewards Points: 252
A picture is worth a thousand words, have one of fixture outlet?
Maybe even the switch pulled from the switch box
Gac66610 is offline   Reply With Quote
Old 09-15-2012, 08:25 PM   #3
Rewards Points: 20
Did you also remove the switches or receptacle when you painted?
daveb1 is offline   Reply With Quote
Old 09-16-2012, 02:02 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,102
Originally Posted by Eric D Thomas View Post
Hi:
et
You must have a switch loop originating from the light !
And you have hooked up the hot supply to the light
on the wrong side of the switch loop.
Find the two wires that go off to the switch,
and put the hot supply to the light on the other wire !
dmxtothemax is offline   Reply With Quote
Outside water tap has never worked jimmyfingers Plumbing 10 07-26-2012 09:40 PM
switch phases and the machine worked correctly n175h Electrical 47 05-02-2012 10:32 PM
Trane XE80 worked yesterday - won't come on today flounder HVAC 29 01-15-2012 12:26 AM
new light fixture won't work after having worked fine initially docchanka Electrical 17 08-29-2011 09:07 PM
gutter covers that worked? pompidoi Roofing/Siding 3 06-23-2011 11:03 PM
