Workbench Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2012, 06:21 PM   #1
Workbench wiring
Hello,
I have a very simple question. I am wiring a parallel circuit of 4 plugs into a metal workbench. I know very little about electronics and want to make sure I am doing it right as I am in a shared space and don't need to go shorting the system or anything. I have:
A single switch with a ground
A 15A single pole circuit breaker with only two spots for wires
A length of extension wire with a male plug
4 x 15A outlets
The outlets are wired and installed with all of the black, white, and ground wires going to their respective places on each one.
My first question is about the switch and the circuit breaker: Do I put those both in line on the black (hot) wire between the male extension cord plug and the first outlet?
My other question: should I attach/bolt the green ground to the metal bench somewhere so it doesn't ground into me or something else if a hot wire was to touch it at the same time as me?
What I think is that the wiring should be as follows:
For the black wire: extension cord>breaker>switch>parallel outlets
For the white wire: extension cord>parallel outlets
For the green wire: extension cord> ground on bench>ground on switch>ground on parallel outlets
Any insight would be helpful
Thanks!
bigflat is offline   Reply With Quote
Old 02-13-2012, 07:27 PM   #2
Rewards Points: 2,512
Originally Posted by bigflat View Post
Hello,
I don't think so. You should really put up some pictures.
hammerlane is offline   Reply With Quote
Old 02-13-2012, 07:32 PM   #3
" Euro " electrician
frenchelectrican's Avatar
The extendison cord is not a perament useage item for perament useage you have to use the NM or other approved type materals to do the job right.
So please tell us what type of extendison cord ya yapping about ??
Once I know your answer one of us will give you a answer.
Merci,
Marc
Old 02-14-2012, 01:36 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
You definitely need to post pictures of this. Your description doesn't use standard terminology and some aspects of this sound rather odd in very specific ways.
mpoulton is online now   Reply With Quote
Old 02-14-2012, 05:24 AM   #5
Old 02-14-2012, 08:26 AM   #6
Please don't hard wire the thing. Easiest thing if you ever move the table is to get an inlet, they make them for trailers. On board I suggest armored cable in such an enviro, and a gfci for the whole circuit
sparkyjake is offline   Reply With Quote
Tags
household , power strip , single pole , wiring
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 11:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
