Old 01-26-2009, 11:11 PM   #1
DIY'er
jamiedolan's Avatar
Work Gloves
HI;
Are there any work gloves that are flexible enough to allow you to work on stuff with the gloves on (handle screws, wire nuts etc.), while still protecting your hands?
My hands are so beat up I keep bleeding all over the place while I am working on stuff.
Jamie
Jamie Dolan - Neenah, WI
Need Help Uploading Photos?
jamiedolan is offline   Reply With Quote
Old 01-27-2009, 06:57 AM   #2
Man of many hats
wrangler's Avatar
Work Gloves
The best gloves I have found for that purpose are made by Plainsman. They are Cabretta goatskin and are very thin, but protect your hands while still allowing great dexterity. I buy mine through Sams club for $17.86 for two pairs. I can even dial my cell phone with them on. I wear through them faster than I do a regular pair of work gloves, but feel it worth the cost to not have to remove them over and over.
Man of many hats
wrangler is offline   Reply With Quote
Old 01-27-2009, 06:57 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Work Gloves
I wear Atlas Therma's in the winter time.
http://www.perfectfitglove.com/produ...2&pseriesid=19
Old 01-27-2009, 07:18 AM   #4
Electrician
SD515's Avatar
Work Gloves
I use Sears/Craftsman 'Ultra Touch' gloves. I have small hands and have a hard time finding ones that fit. Usually medium is the smallest size I can find by most manufacturers, and usually are too big. I like them to be 'skin-tight', so I don't lose dexterity...I've learned to be able to pickup the smallest of washers and such with them. Takes a couple of days to 'break them in', and usually I go through a pair a month, but it's cheap compared to having cuts and tears on my hands.
Kyle
Old 01-27-2009, 11:24 AM   #5
Learning by Doing
Leah Frances's Avatar
Work Gloves
I like high quality goat skin gloves - I get mine at TSC - they have better selection for the ladies.
For fine dexterity, with some minimal protection, I throw on some latex/nitrile gloves. They don't really act as a barrier, more an early warning/detection system. I like them alot for 'scratchy' projects in the winter time.
Sometimes it's just enough to keep me from skinning a knuckle. And usually, if I stop to put on some nitrile gloves I will think to myself, "maybe I should get some real gloves on."
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-27-2009, 02:39 PM   #6
DIY'er
jamiedolan's Avatar
Work Gloves
Thank you for all the suggestions.
I checked and our local sams club did not have any of the gloves in stock, although from the photo on the web I thought I had seen them there in the past, so will check again.
I ran to sears this AM and tried on several different gloves, and ended up getting a pair of the Ultra Touch. I got a medium pair that seems to fit very well. So far I have been able to work and do most things with them on, couldn't get a roll of electrical tape started for anything...
Thanks again for the suggestions. I just need to give my hands some time to heal up for all the damage.
Jamie
Old 01-27-2009, 03:21 PM   #7
Work Gloves
I want to buy such gloves (able to handle small screws and washers etc). but could not find in New zealand. Is it possible to get it online from reliable source.
Could you give me reliable source then I can order from them. I feel it is worth to pay up to 20$ per pair.
mpj111 is offline   Reply With Quote
Old 01-27-2009, 05:51 PM   #8
Electrician
SD515's Avatar
Work Gloves
Originally Posted by jamiedolan View Post
...couldn't get a roll of electrical tape started for anything...
I can't get a new roll started with the gloves on either. Usually can after it's been used. Either way, don't tell the wife I use my teeth sometimes to start the tape...lol
I know that feeling...
Kyle
Old 01-27-2009, 05:54 PM   #9
Electrician
SD515's Avatar
Work Gloves
Does Sears have stores or ship to New Zealand?
Kyle
Old 01-27-2009, 08:30 PM   #10
Man of many hats
wrangler's Avatar
Work Gloves
I saw that Sam's Club even had some available in their "auctions' section, but I do not know if they ship to NZ. If not, maybe you could have a stateside friend ship them to you?
Man of many hats
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Does your job require a permit? housedocs General Discussion 203 12-01-2010 08:28 AM
Is it right that an owner must be licensed to perform work joey b Electrical 45 12-16-2008 11:16 AM
Trying to get swith to work... mntentman Electrical 4 09-19-2008 09:54 PM
What gloves to wear when working with electrical? twilightcall Electrical 7 01-04-2008 06:34 PM
