Old 05-31-2007, 02:18 PM   #1
Work boxes?
When attaching a new work box to a stud, how far off of the stud do you put it? I figure you want it flush with the drywall so you should bring it out as far as it would take to set flush with the drywall?
sandyman720 is offline   Reply With Quote
Old 05-31-2007, 03:55 PM   #2
Work boxes?
Correct. They usually come with indicator lines imprinted on the side of the box. One for 1/2" and one for 5/8 drywall I think.
send_it_all is offline   Reply With Quote
Old 05-31-2007, 04:28 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Work boxes?
Yes, you don't want it to be ''over'' the sheetrock surface thickness - or the cover plate will sit extended (floating).
If you end with with a few boxes ''under'' the surface thickness of the sheetrock, that is ok.
- Build Well -
Old 05-31-2007, 04:55 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Work boxes?
Up to 1/4" set back is acceptable with drywall.
Old 06-01-2007, 11:22 AM   #5
RippySkippy's Avatar
Work boxes?
If the plastic ones stick proud, you can always take a sharp saw like the pull saw and trim it back to the drywall...a minute or so will have the face plate sitting nice and flush....DAMHIKT. Metal boxes are another beast. As for installing, I usually have a template for thickness and heights so they are all the same.
RippySkippy is offline   Reply With Quote
Old 06-01-2007, 03:33 PM   #6
Home Improvement Guy
ron schenker's Avatar
Work boxes?
If this still doesn't feel right, cut a little piece of the drywall that you will be installing and use that to measure.
ron schenker is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Boxes recessed too deep rondo Electrical 10 12-01-2012 07:46 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
is this bad tiling work? garrick Flooring 17 09-27-2006 01:30 AM
