Work Box In Between 2 Studs - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2007, 08:20 PM   #1
Rewards Points: 152
Work Box in between 2 studs
How do you place a work box in between 2 studs?
sandyman720 is offline   Reply With Quote
Old 09-11-2007, 08:29 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
How close are the studs?
Old 09-12-2007, 05:14 AM   #3
Rewards Points: 152
16" o.c.
Old 09-12-2007, 05:27 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
I don't get the question.
How about a bit more detail.
Old 09-12-2007, 06:40 AM   #5
Licensed Pro
Cut it in after the wall covering is up?
Old 09-12-2007, 06:52 AM   #6
Rewards Points: 152
The question is:
For a new construction home, how do you put in a "new work" receptacle box if you want to place it in between 2 studs.
For example if the middle point between 2 windows falls between 2 studs and you want to put a sconce there.
Matt
Old 09-12-2007, 07:24 AM   #7
Licensed Pro
1. Cut in after wall is finished (easiest)
2. Use light box with integral mounting bar
3. Cut 2x4 to fit and mount box to that.
Old 09-12-2007, 05:16 PM   #8
EXACTLY
Old 09-12-2007, 09:52 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
One other thing is be careful on the box size. Some sconces will not cover a 4 inch round. Some big boxes are now carrying the smaller boxes and specialty boxes to allow for applications like sconces.
Stubbie
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
is this bad tiling work? garrick Flooring 17 09-27-2006 12:30 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
