Woods Time Switch 59396 - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 12:22 AM   #1
Question
woods time switch 59396
I am trying to replace a timer that no longer works, I believe it is an Intermatic that I currently have, it has just three wires: green, white, and black. I had gotten a Woods 59396/59399 and got a little confused on how to wire it. This is to control some lights.
wk1776 is offline   Reply With Quote
Old 09-29-2011, 01:30 AM   #2
" Euro " electrician
frenchelectrican's Avatar
It don't really sound right on the numbers of conductors you will have incomming { line } and outgoing { load } sources so please take a look again.
BTW this is a hevey duty timer it will handle up to 30 amp load
The wiring diagram is bottom of the PDF so you should able hook this one pretty easy just pay attetion to the supply and load side.
http://www.smarthome.com/manuals/56028.pdf
Merci,
Marc
Old 10-05-2011, 11:52 PM   #3
i did double check and i do only have the three wires currently
Old 10-06-2011, 12:46 AM   #4
Where did the three conductors goes ?? to the load centre or junction box for the lumianires ?? that will give you some clues on the set up.
Merci,
Marc
Old 10-06-2011, 10:35 PM   #5
I am not really sure where the wires all go, one is black, one white and one green, the wires are all enclosed in conduit till the timer. the breaker box is probably 60 feet away atleast, and the lights are on different floors
Tags
59396 , wood time switch
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Electric Time Switch David Cosner Electrical 2 03-30-2011 11:15 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
