Won't Fit. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-27-2008, 02:53 PM   #16
Plastic boxes don't NEED a tri tap .
You can use drywall screws if you need longer screws (the point on the DWS makes finding the hole/starting the screw a lot easier.
IMO, the main problem with metal boxes is that they are conductive. They also take longer to install and generally have less volume.
220/221 is offline   Reply With Quote
Old 10-27-2008, 06:57 PM   #17
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by williswires View Post
That's a lot of wires. Assuming you have all 14 AWG wires in there, your required box volume is a minimum box having at least 38 cu. in. Most of the Carlon 2-gangs have 32 or 35, but maybe yours is bigger.
Now, for Jamie's concern.
Jamie should have a box volume of at least 44 cu. in.
If a gangable box type like this is used, a 2-1/2" deep won't cut it at approx 37.5 cu in. A 2-3/4" deep is close, at approx 42 cu in. The next size is usually 3-1/2" deep, offering approx 54 cu in, but the screws for the cable clamps usually hit the opposite wall.
If this style is used, I would use the 2-3/4".
Now, if this style is used, a 2-1/8" deep box will give 44.3 cu. in., but might be a little tight putting a dimmer or deep switch in there.
willis
Yes, that metal box shown above with the detachable side is just what I have, I had a 2 gang, and I added another box to it to make it a 3 gang.
It is only about 2.5" deep at the most.
I bought a new 3 gang plastic box that is deeper, it is 52 cu in box. I was working on a different box today, it is was a 46 cu in plastic box. It has five 14-2 and one 14-3 in the box.
Actually I was mistaken with the number of wires going into the box we are discussing here. It actually has:
4 - 14-3
2- 14-2
6 pieces of romex going in, but 4 of them are 14-3. For a total of 16 wires that either terminate or junction in that box. Plus the ground wires.
I will be replacing the metal box tommrow with the new 52 cu in plastic box and re feeding all 6 cables to it.
These 3 / 4 way switches sure do get to be a little bit of work don't they...
And next up, fishing through an insulated wall to install a new light fixture outside, and then I am going to install AC smoke detectors, while I have a number of celings ripped open.
Maybe someday I will be able to spend some times rebuilding my kitchen that I gutted 2 months ago.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-27-2008, 06:59 PM   #18
DIY'er
jamiedolan's Avatar
Nuts too....
I have been using some of the red wide range nuts, they are kind of big. I bought a bag of the yellow wide range, they are much smaller and should help space wise.
Jamie
Old 10-27-2008, 07:58 PM   #19
Electrician
Originally Posted by InPhase277 View Post
Where's the UL listing on the sheath that says it is suitable for use as a means to secure other cables?
Show me a code where the cable support has to be listed?
Next your going to want screws listed for supporting a panel to plywood.
chris75 is offline   Reply With Quote
Old 10-27-2008, 09:12 PM   #20
Rewards Points: 2,350
That wasn't my point. Personally, I wouldn't have done it that way, but overall, the cables are secure. But, where I'm from, the inspector would not pass it because the cable sheath is not a sound mechanical support for the cables.
Old 10-27-2008, 10:01 PM   #21
Electrician
He really doesn't have a choice does he? You either let him beat you up, or you set him straight from the get go. Wait till it starts costing you money, then you will not tolerate this nonsense.
Old 10-27-2008, 10:03 PM   #22
That would be his personal opinion. Mine would differ and I'd be open for a head to head field test agaist those stacker thingys.
Old 10-27-2008, 10:08 PM   #23
Electrician
I personally love the stak-its, but your method is fine as well.
Old 10-27-2008, 10:09 PM   #24
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
While I agree with you and Chris on the listing part, I'd take that bet for my cable stackers against your romex sheathing ANY day!
Old 10-27-2008, 10:23 PM   #25
Oh, you're on!
It's a long drive for both of us so let's come up with a test, Mythbusters style using the same parameters.
I've never used stackers. How do the wires clip in?? Can you grab a cable and pull it out of the wall?
Cable sheath pros:
keeps the cable further from the drywall screws
Keeps sheathing out of the land fill (Yay green!)
Infinitely less material cost. (Yay green!)
Stacker pros: ??
Old 10-27-2008, 10:32 PM   #26
Stacker pros: ??
- SUPER easy installation: One captive nail.
- Infinitely re-usable.
- Not a tight support. Cable can move for adjustment or removal.
- Looks VERY neat when used properly. I am anal about my rough-ins and cable stackers can looks just as nice as my stapling.
- Wide range of cable capacity. Most up to 8 or 10 cables.
Cons:
- Only one real con: Cost. But in the scope of things this is not really a concern to me.
- A minor con is having to stock them
I can VERY easily live with both of these cons.
I use the red GB ones with the snap closure.
Old 10-27-2008, 10:41 PM   #27
One or two staples.
Dont you leave them in the wall??
Same here
Beauty is relative. Mine look the same when the job is done. Only the cockroaches see your stackers
Unlimited range
I gotta go play softball.
To be continued..........................
Old 10-27-2008, 10:42 PM   #28
Electrician
Originally Posted by Speedy Petey View Post
- I am anal about my rough-ins and cable stackers can looks just as nice as my stapling.
I think I would work quite well with you day to day.
Old 10-27-2008, 10:44 PM   #29
Electrician
no need to argue the NM strap vs stacker, either or is fine. IMO though the NM strap could have some derating issues to contend with depending on the situation.
Old 10-27-2008, 10:45 PM   #30
I get that impression as well.
