Wirring In An Attic - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2008, 03:14 PM   #1
wirring in an attic
i live in mich. and want to know if running wires in an attic if you have to drill through rafters or staple them along them?
lineman08 is offline   Reply With Quote
Old 11-02-2008, 03:19 PM   #2
the Musigician
DangerMouse's Avatar
i'm using 1x3 furring strips mounted to rafters, then stapling to that. the inspector liked it. =o)
DM
Old 11-02-2008, 04:47 PM   #3
Rewards Points: 876
I should be asking the same question, as I will soon need to run a couple of cables through the attic.
I wonder if the requirements depend on whether the area you are running the cables is high enough to walk in or not.
If the cables are run very close to the floor, along the roof rafters I mean.
To help answer the OP's question, couldn't you simply run the cables along the center of the roof?
Ultrarunner2017 is offline   Reply With Quote
Old 11-02-2008, 04:51 PM   #4
Rewards Points: 876
DM
I like that too. It would result in shorter runs than having to go all the way up to the center of the roof, and save a lot of work in having to rip up floor boards if you want to run under the floor.
Old 11-02-2008, 05:01 PM   #5
ive also heard that you could maybe staple to rafters near the eaves. but i have easy access tto attic floor joists. I guess maybe if you drill you cant go wrong. Beside you wouldnt have to worry about putting a floor in then would ya.
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 07:10 AM
Powered Attic Fan question spup345 Roofing/Siding 9 06-30-2008 08:10 PM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
