Wirl Pool Ground Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 10:07 PM   #1
Rewards Points: 256
wirl pool ground question
can this be ground to the same copper pipe that has a ground from the service panel since that pipe is right there already supplying the tub .
thanks for the answers so far.
i meant whirlpool .
oldrivers is offline   Reply With Quote
Old 04-15-2012, 10:10 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is this a hot tub or a whirlpool in a bathroom?
Old 04-15-2012, 10:11 PM   #3
Rewards Points: 256
whirlpool bathroom .
Old 04-15-2012, 10:25 PM   #4
k_buz's Avatar
Run a #8 solid CU to both the lugs pictured continuous to the cold water copper pipe and connect it with a J-Clamp
Old 04-15-2012, 10:27 PM   #5
k_buz's Avatar
I should clarify, that the cold water pipe you bond to would need to be copper all the way back to the meter. You could not have plastic water piping between the whirlpool and the meter.
Old 04-15-2012, 10:58 PM   #6
Rewards Points: 256
heres a rough basic idea of what im dealing with.
Old 04-15-2012, 11:18 PM   #7
k_buz's Avatar
Yeah, that should work.
Old 04-16-2012, 06:12 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
This is a bond, and does not need to extend to the water meter. That first illustration is not correct. There is NO need or requirement for this wire to be connected to an equipment ground.
This wire is simply bonding all the metallic parts of this system and the metallic piping associated with the tub.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
bob22 (04-16-2012)
Old 04-16-2012, 09:00 AM   #9
k_buz's Avatar
The cold water pipe would have to be CU all the way back to the meter.
Old 04-16-2012, 11:13 AM   #10
Rewards Points: 204
The EGC is all that is required for this application.
The Following User Says Thank You to J. V. For This Useful Post:
Speedy Petey (04-16-2012)
Old 04-16-2012, 03:15 PM   #11
Not for this application it wouldn't.
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 04:21 PM
Ground bar neutral bar question? jjrbus Electrical 4 07-07-2011 06:31 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 08:41 PM
Ground Clamps Question integlikewhoa Electrical 40 02-28-2008 09:13 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
