Currently used bedroom, but trying to convert a corner for hobby work and etc. I want to install another outlet and a switch for an overhead light. The room is on a 15a. breaker that shares with a bathroom light only. So I shouldn't have a problem with overloads. Although, when the house was built, it only has 1 outlet on each wall, 4 total. The one I want to use is behind a bed, so I want to "move it" without going into the walls.
I drew a diagram of what I want and where. Are the plans good?
I need a way to tap into the outlet without going into the walls. Is there a metal "box extender" similar to wiremold that will screw over a plastic j-box in the wall. It needs to accept surface mount 1/2" or 3/4" EMT metal conduit that will run 14 gauge THHN/THWN to the outlets and switch.
I also will have a GFCI on the first outlet near the desk for the other too "not including the light" since I work with water/paint too.
