Old 01-23-2013, 02:18 AM   #1
Wiring well pump problems
first time user so sorry if it don't make sense.
I have an old Franklin Electric well pump and cant see the wiring info in control box cover. my question is: If there is a burnt orange wire on the relay switch, what problems will stem from it.
phoward2120 is offline   Reply With Quote
Old 01-23-2013, 08:59 AM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... Burnt wirin' is Always a Problem....
Got a picture, if ya can't Explain the problem,..??
Old 01-23-2013, 09:09 AM   #3
As long as you do not expect to have water it's not a problum.
Could have been anything from a lightning strike, under size wiring running to it, loose connection, bearings going bad causing it to draw more amps, loosing the nutral.
Old 01-23-2013, 09:14 AM   #4
Idiot Emeritus
Depending on where it's burned, it could very easily burn the component it's attached to. Like the start relay.
In any case, once a wire begins to burn, it'll only get worse.
Rob
micromind is offline   Reply With Quote
Old 01-23-2013, 06:28 PM   #5
joed's Avatar
Burnt usually indicates heat. The connection or crimp on lug probably needs to be changed. cut back the wire to soft flexible insulation and put it back under the connection.
Do not PM with questions that can be asked in a forum. I will not respond.
Well pump wiring code question rjniles Electrical 12 04-21-2012 11:54 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
New Heat Pump Problems Cooling Zombify HVAC 2 04-06-2010 04:42 PM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
pump wiring konafixits Electrical 23 07-07-2008 10:55 AM
