-   -   Wiring well pump problems (http://www.diychatroom.com/f18/wiring-well-pump-problems-169877/)
phoward2120 01-23-2013 01:18 AM
:eek: first time user so sorry if it don't make sense.
I have an old Franklin Electric well pump and cant see the wiring info in control box cover. my question is: If there is a burnt orange wire on the relay switch, what problems will stem from it.
Bondo 01-23-2013 07:59 AM
Ayuh,.... Burnt wirin' is Always a Problem....
Got a picture, if ya can't Explain the problem,..??
joecaption 01-23-2013 08:09 AM
As long as you do not expect to have water it's not a problum.
Could have been anything from a lightning strike, under size wiring running to it, loose connection, bearings going bad causing it to draw more amps, loosing the nutral.
micromind 01-23-2013 08:14 AM
Depending on where it's burned, it could very easily burn the component it's attached to. Like the start relay.
In any case, once a wire begins to burn, it'll only get worse.
Rob
joed 01-23-2013 05:28 PM
Burnt usually indicates heat. The connection or crimp on lug probably needs to be changed. cut back the wire to soft flexible insulation and put it back under the connection.
