Wiring A Well Pump Plug Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 01:49 PM   #1
wiring a well pump plug question
I have a two wire submersible well pump that I want to put a plug on to run off my generator. I have the plug and it has four prongs that fits my generator, and the well pump has only three wires (white/black/ground) how do I wire it
thanks much
Ridgerunnertc is offline   Reply With Quote
Old 06-03-2012, 02:00 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
thanks much
Buy one of these....
http://reliancecontrols.com/ProductDetail.aspx?CSR202
Buy the one that matches your generator output, either 20 amp or 30 amp....
Old 06-03-2012, 02:05 PM   #3
cant I just plug it into the generator
Old 06-03-2012, 02:06 PM   #4
E2 Electrician
Does it normally run off Utility power?
Old 06-03-2012, 02:32 PM   #5
yes it was wired to a moblie home that was moved but we need to well for irrigation
Old 06-03-2012, 02:34 PM   #6
E2 Electrician
If you are going to run this pump off of two sources of power, then you have to install a transfer switch. Besides making this a code compliant installation, it will save you a ton of headache every time you lose Utility power.
IF you only plan on running the pump off the generator, then we'll need the well pumps nameplate.
Old 06-03-2012, 02:38 PM   #7
the utility power is gone, we had it taken out when the moblie home was moved - just need the well for temporary use and the plug would be installed perm.
Old 06-03-2012, 02:39 PM   #8
E2 Electrician
Figure out the correct voltage on that pump, and then I would just install one of these on a post and tie the well pump wire into it, this way you can just run a cord set from your generator to this access point.
Old 06-03-2012, 02:45 PM   #9
ok thanks - but how does the two wires plus ground out of the well pump wire a 4 prong plug
Old 06-03-2012, 02:58 PM   #10
E2 Electrician
Your generator is supplying 120/240 volts, two hots, a neutral, and a ground...
Your well, depending on its voltage, is either going to only use two hots and the ground, (240v only) OR one hot and a neutral and a ground (120v only) this can be accomplished by only terminating the well wires to the correct spots on that inlet receptacle I posted.... But you have to know what voltage the well pump is. Im guessing 240v....
Low Voltage Wiring Question.. scyarch Electrical 3 10-23-2011 12:00 PM
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 07:56 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Wiring a geothermal pump gfmonk Electrical 5 11-14-2009 03:30 PM
Sump pump drainage question famdog Plumbing 1 01-05-2009 02:42 PM
