Wiring For Welder Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2006, 12:49 PM   #1
wiring for welder plug
Hi,
I'm installing a small welder (230 v, 50 amp) in the garage and I'm not sure about the wiring for the plug-in.
The power supply was formerly used for an electric range. It was a four-prong receptacle with black, red, white, and ground wire. The new receptacle for the welder is a three prong. Which color wire goes where?
Any advice would be much appreciated. Thanks
Bullmoose is offline   Reply With Quote
Old 12-02-2006, 12:55 PM   #2
World famous jerk.
The white will not be used for your welder rec. Put the blacks on X and Y, put the ground on the green or G. Have a ball.
mdshunk is offline   Reply With Quote
Old 12-02-2006, 12:59 PM   #3
Thanks Mdshunk,
Sorry, but I don't understand.
You said blacks. I have only one black wire.
Old 12-02-2006, 01:18 PM   #4
World famous jerk.
Originally Posted by Bullmoose View Post
Thanks Mdshunk,
Okay, black on X, red on Y, ground on G or green. White will be unused.
Old 12-02-2006, 01:27 PM   #5
The (welding) sparks are flying! Thanks mdshunk.
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Wiring plug to Mercury High Intensity ballast Dustin Electrical 2 05-29-2007 05:56 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
wiring a usa plug Unregistered Electrical 5 02-28-2004 12:57 PM
