Wiring A Water Well - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2008, 06:44 PM   #1
wiring a water well
what type of wire should i use to run from the fuse box, about 5 feet, to my gould's above ground shallow well jet pump (JS Plus) that supplies water to my house? i want to replace the 45 year old wire that is currently there. it is half horse power and my electrical amperage is 120v. it is in a pit in the ground, but it is protected from the weather by a hatch.
thank you!!
baileyboo is offline   Reply With Quote
Old 03-20-2008, 06:54 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by baileyboo View Post
wit is half horse power and my electrical amperage is 120v.
NO, your "electrical amperage" is not 120v.
Let's start with the basics:
What is the amperage of the motor?
What is the voltage of the motor?
Old 03-20-2008, 08:18 PM   #3
" Euro " electrician
frenchelectrican's Avatar
C'est simple if your motor have nameplate info use that info for getting the correct wire size and voltage connection and how far it away from main breaker box ??
we are instering with the motor amp , motor voltage supply , distance from main breaker box to the motor itself [ the distance will really count here ]
Merci , Marc
Old 03-21-2008, 04:09 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
one HP = 746 watts (approx)
half HP= 375 watts (rounding)
Current (amperage ) = 375 / 120 volts = less than 4 amps
Motors vary but this calculation is close enough
You state distance is short
Use 14-2 UF cable (due to wet location)
Based on your misuse of terms, I assume you are a novice, I suggest you hire some one who is knows what is required
rjniles is offline   Reply With Quote
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
